Results 1 to 4 of 4
    Exclamation LG Optimus F3 Persistent Message
    I have an LG Optimus F3 with T-Mobile. Last night, I received only the second half of a two part text message. When I click on the message in notifications, it prompts me to draft a new message. It does not appear in the thread of messages with the contact. When I clear my notifications, it quickly pops up again (if it disappears at all). Force stopping the app prompts the message to return as soon as I receive a new message. I have turned my phone on and off and pulled the battery several times each. It is really frustrating as I am unaware when I actually have unread messages without manually checking them and it has been causing the screen to light up often, draining the battery.
    Has anyone else experienced a similar problem? Any ideas as to fix it? Thank you so much for any help you can provide!
  2. #2
    Default Re: LG Optimus F3 Persistent Message
    I Have the same problem. I turned off message notifications and this helps but then I don't know when I get new messages at all. I feel it has to be the service not the phone. Because the phone doesn't know that the message is even there! Have you resolved your issue?
  3. #3
    Welcome to Android Central! Try going to Settings>Apps>All, select Messaging (or whatever the texting app is called), and Clear Cache. If that doesn't work, then you could Clear Data, although you'll lose any saved messages.
  4. #4
    I tried that. Didn't work. I turned off notifications, downloaded another messaging app because I can't uninstall the stock one for whatever reason. Just started using Messaging 6 (looks like an iphone now when i text) It's just a patch up job but sometimes that's what you nee to do when the creators of the phone don't let you uninstall and re-install their faulty program.
  1. LG QuickCover users?
    By flick0416 in forum Nexus 5 Accessories
    Last Post: 05-21-2016, 03:45 PM
  2. LG G Pad 8.3 GPe vs Samsung Galaxy Note 8.0???
    By rorobynbyn in forum LG G Pad 8.3 Google Play edition
    Last Post: 02-11-2014, 08:47 PM
  3. Samsung Galaxy Note 8.0 vs LG G Pad 8.3 Google Play ed.
    By rorobynbyn in forum Samsung Galaxy Note 8.0
    Last Post: 02-04-2014, 07:45 AM
  4. How to listen to Recorded Messages on Galaxy S4?
    By dbehrmann in forum Samsung Galaxy S4
    Last Post: 02-03-2014, 11:25 PM
