Results 1 to 9 of 9
    Default "Couldn't prepare instant mix. Please try again." (SOLUTION) for Touchless Controls
    So you just bought a Moto-X and you updated to the latest software of Google Play Music so you can fully experience and enjoy the touchless controls when playing your music content!
    Well that's just the problem, The latest update may have a bug that prevents you from playing the music you want with the touchless controls because it wants you to use the Instant Mix to play the song.
    You can easily solve this issue by following this instruction right below:
    Settings -> Apps -> All -> Google Play Music -> Uninstall Updates to Google Play Music. (DONE!)
    The source of the bug is from "instant Mix" and by removing the update that gives you that feature, you will now be bug free when using touchless controls to play your songs.
    If this solution has helped you out, please let me know because it defiantly helped me out!
    Thanks! =)
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,914 Global Posts
    ROM
    Stock Moto X
    Default Re: "Couldn't prepare instant mix. Please try again." (SOLUTION) for Touchless Controls
    Is this for the 4.4 version? I am still on 4.2, and I have no bugs like this.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu 'If we could change ourselves, the tendencies in the world would also change.' - Mahatma Gandhi
    Community Guidelines and also here
    Quote Originally Posted by Golfdriver97 View Post
    Not sure which version I had before but my Google Play is currently Version 5.2 which is how it was factory settings on my Moto X phone.
    I just hope this helps for those with the bug! =/
  4. #4
    Posts
    Global Posts
    13,914 Global Posts
    ROM
    Stock Moto X
    Quote Originally Posted by DreamyAbaddon View Post
    Sorry, I meant Android version.
  5. #5
    vtpmt81's Avatar
    Posts
    Global Posts
    140 Global Posts
    This does not work if you are on 4.4.2.
  6. #6
    Unfortunately, while that solution worked in 4.4, the old problem of the instant mix feature interfering with the ability to play a song using Touchless Control has returned since the update to 4.4.2, and now there appears to be no similar solution. I tried all manner of uninstalling updates, uninstalling the app and reinstalling, rebooting, importing a different music player app, etc., with no success. Then I called Motorola tech support and, after explaining the problem to a couple of technicians, I was able to reach a "Level 2 support" person, who said that they are aware of the problem and "the developer is working on it." If anyone comes up with a solution, please share. After having the feature work for a couple of months, now I miss the ability to use it.
  7. #7
    This bug really ruins the Google Play Music app for me. I would like to use touch less controls to play the music that is already on my phone but keep getting error (couldn't prepare instant mix please try again) It seems like there should be an easy fix for this. Are there any other apps other than "Play Music" that we could use to play music with Google now?
  8. #8
    The instant mix feature actually works when it is not connected to the internet on my Moto G, but not while it is connected.
  9. #9
    For me, it works when connected to the Internet via mobile data, but not when connected via WiFi.
  1. How do I create input? Please help me regain control!
    By FutureKix in forum Android 2.3 Gingerbread
    Last Post: 02-21-2014, 02:30 PM
  2. 'No OS Installed! Are you sure you wish to reboot?' PLEASE help!
    By Julian Uribe in forum HTC One Rooting, ROMs & Hacks
    Last Post: 02-14-2014, 10:30 PM
  3. Need your help please read
    By spmorgan999 in forum Android 2.3 Gingerbread
    Last Post: 02-03-2014, 10:27 PM
  4. How to Install new OS through SD card Only? Please Help
    By roadrunner914 in forum Epic 4G Touch Rooting, ROMs, and Hacks
    Last Post: 02-03-2014, 09:58 PM
  5. Deleted htc desire os please help!
    By Dakota Bullion in forum General Help and How To
    Last Post: 02-03-2014, 08:38 PM
B
