1. jiri463's Avatar
    Hi,
    I have been using HTC Desire X for 1 year. Now I have bought Xperia SP, because HTC wasnt so fast (not games etc., but in normal use, long delay before app start, twitching at main screan rolling etc. ). So Xperia is faster, not as I expected, but still faster until I put my SD Card from HTC. After that Xperia bacame slow like HTC. My SD card is the expensive one Kingstom 32 GB. Is it all only because of SD card? Can you say me some info about SD cards and Android? I am really disappoited about that. Thank you for your aswer.
    02-04-2014 08:07 AM
  2. Rukbat's Avatar
    1) SD cards come in different speeds. A Class 4 (4MB/s) card will be a lot slower than a Class 10 (10MB/s) card.
    2) If the card isn't formatted correctly (although I've never noticed one phone needing a different format than another), it could affect speed.
    I think #1 (and the fact that you can't trust the label on the box) is the largest factor. Install SD Insight (free at the Play store). Run it. Press the little "eye" in the upper right corner. It will tell you what the card says it is, how fast the card says it is, etc. I've seen 2GB Class 4 cards in packaging labeled 32GB Class 10.
    There are only 2 manufacturers of the chips in the cards, SanDisk/Toshiba (a joint venture) and Samsung. EVERYONE ELSE buys chips or used cards and relabels them. Since SanDisk is a better company to work with, and their prices are cheaper, they're the only cards I ever buy. And the only problem I've ever had is losing a few cards. (My wife cleaned up my desk and I have no idea where the cards are.) I still have 4GB SanDisk cards (from when 4GB was as large as they got) that still work.
  3. Paul627g's Avatar
    Yes the SD card can effect performance. Did you format the card after swapping it to the Xperia?
    02-04-2014 08:33 AM
  4. VDub2174's Avatar
    Welcome to the forums!!
    I think it really depends on what's on the SD card.
    02-04-2014 08:34 AM
  5. Rukbat's Avatar
    02-04-2014 11:43 AM
  1. Android 4.0 unable to recognize USB mass storage
    By cplloyd42 in forum Samsung Galaxy Tab 7.7
    Last Post: 02-18-2014, 03:24 AM
  2. Save image/video thumbnails to external storage card
    By silentpond in forum Samsung Galaxy S3
    Last Post: 02-05-2014, 12:53 PM
  3. KitKat update with Android Revolution on HTC One
    By ihsaaan in forum HTC One M7
    Last Post: 02-04-2014, 08:09 AM
  4. Save image/video thumbnails to external storage card
    By silentpond in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-04-2014, 05:03 AM
