1. nrz74's Avatar
    Hi, I'm setting up my first Android phone this week and I have my first question that I haven't been able to find an answer to. I have an HTC One mini running Android 4.2.2 with the HTC Sense 5.0 overlay on the AT&T network.
    In the default Phonebook app there are 5 panels: Call History, Phone, Favorites, Contacts, & Groups. I have my numbers setup in Contacts in the (xxx) xxx-xxxx format, but in the Call History and Phone panels (and I assume the Favorites panel, if I had favorites stored yet), the phone numbers appear in the xxxxxxxxxx format, which I absolutely can't stand. I find it very difficult to read and an unfriendly way of displaying phone numbers.
    Is there a way to modify this using the default app? If not, is there a replacement phone app that works in much the same way and is known to be stable with a light footprint?
    Thanks!
    02-05-2014 05:56 PM
  2. Golfdriver97's Avatar
    I can't answer about the default app as my two devices run AOSP dialers and contacts which are set up the way you prefer. I would look at apps I Play.
    02-05-2014 11:34 PM
  3. nrz74's Avatar
    Golfdriver97, thank you for your reply. I found a few phone apps on Google Play, but none of them seemed to be what I'm looking for. I'm assuming I would need to root, or at least significantly overhaul my system, to take advantage of the AOSP dialers you mention? I'm looking for something simple for a beginner, so if it's going to be a lot of hassle, I think it'd be over my head at this time.
    02-06-2014 06:58 AM
  4. Golfdriver97's Avatar
    You are correct that you would need to root and flash an AOSP ROM, like CyanogenMod. I am not familiar with rooting HTC devices, and rooting is not for the faint of heart.
    From a Sprint Moto X using AC Forums app
    02-06-2014 08:41 AM
  5. nrz74's Avatar
    I was hoping editing the phone number format display would be as easy as editing an XML file or something like that or going to some hidden, advanced settings menu. It appears that is not the case and I'll just have to live with the xxxxxxxxxx format until an Android update fixes it or someone comes up with a better Phone app, correct?
    02-06-2014 08:55 AM
  6. Golfdriver97's Avatar
    Yes, hopefully an update will be soon.
    02-06-2014 10:28 AM
  7. nrz74's Avatar
    Okay. Too bad. Thanks for your responses, though!
    02-06-2014 10:38 AM
  1. Saving Pictures to my SD Card
    By CrazyTwitterFreak in forum Samsung Galaxy S4
    Last Post: 03-06-2016, 11:41 PM
  2. Replies: 8
    Last Post: 02-07-2014, 10:03 AM
  3. rooted phone now how to get rid of junk
    By allysisa in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-06-2014, 05:40 AM
  4. getting rid of dock
    By dyerdiehl in forum General Help and How To
    Last Post: 02-05-2014, 09:59 PM
  5. Nexus 7 (G1) linking to TV/Youtube
    By studoubletwo in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-05-2014, 06:49 PM
