1. 13iron's Avatar
    I get a contact prediction (after typing a few letters) that i don't want. its an email address that was associated with a spam/phishing (at least i think so) listing on a website i visited. it doesn't show in the people app for my contacts. so its located somewhere else? how do i erase the prediction? I've cleared caches of emails and its not from my keyboard (as you can tell from the attachment) but still pops up. any help would be great! thnx
    02-06-2014 11:34 AM
  2. 13iron's Avatar
    if it helps, moto x on Republic Wireless running stock 4.2.2
    02-06-2014 11:38 AM
  3. UJ95x's Avatar
    If you've received emails from them you should also be able to add them to a blacklist. That way they can NP longer send messages, I'm pretty sure that will delete the prediction as well
    13iron likes this.
    02-06-2014 11:55 AM
  4. 13iron's Avatar
    ok, thnx. where would that 'blacklist' be located? both gmail and ymail? can it be done in the app or only on the desktop versions?
    02-06-2014 12:03 PM
  5. UJ95x's Avatar
    I use the desktop version. You'd have to login with your email and in the settings there should be an option to block email addresses
    Sent from my SGH-M919 using AC Forums mobile app
    srkmagnus and 13iron like this.
    02-06-2014 12:09 PM
  1. How do you disable ringtone for a contact?
    By heading4tomorrow in forum LG G2
    Last Post: 08-14-2014, 10:23 AM
  2. Outlook contacts no longer sync
    By cjb44 in forum AT&T Galaxy S III
    Last Post: 04-15-2014, 03:34 PM
  3. Get Phone to use same number format as Contacts
    By nrz74 in forum General Help and How To
    Last Post: 02-06-2014, 10:38 AM
  4. Replies: 1
    Last Post: 02-05-2014, 09:40 AM
  5. Can't add or edit contacts
    By jakman50 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-05-2014, 09:03 AM
