Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Golfdriver97
    Brett Sholar's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Android Word Prediction
    Hello,
    I can't seem to find an answer to this problem, so hopefully somebody knows.
    I use the native keyboard, and I once used caps to emphasize a word by typing "I JUST..." in a text, and now anytime I type "I" followed by "just," the text prediction changes it to "JUST."
    Obviously this isn't desired, and since "just" is a word, nothing has been added to the personal dictionary in order for me to delete it. I have no idea how to get my phone to stop predicting "JUST" without resetting all of the keyboard data.
    If it helps:
    HTC Droid DNA
    Android 4.2.2
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Android Word Prediction
    Quote Originally Posted by Brett Sholar View Post
    Hello,
    If it helps:
    HTC Droid DNA
    Android 4.2.2
    Welcome to the forums.
    Try a different keyboard app. I use Google's and it properly corrects it. I tried many variations of I just and it properly corrected me.
    Relletti likes this.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Using a different keyboard shouldn't be required to fix that issue.
    I did turn off word prediction for a little while, and after I turned it back on, it started behaving properly again. Maybe this is a hidden way of getting the prediction system to reset itself.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    You may be able to long press the word prediction (JUST) and delete it from the dictionary. See if that helps and clears out the prediction.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It started happening again, and I've tried deleting the word. Long pressing doesn't work.
  1. Steve Wozniak thinks Apple should build an Android smartphone
    By propeller10 in forum General News & Discussion
    Last Post: 02-07-2014, 10:58 AM
  2. Stress buster android app
    By supermonkeyfun in forum Android Apps
    Last Post: 02-07-2014, 02:24 AM
  3. NEED replacement screens for "MID Google Android 4.0 1.2GHz 4GB 7" Tablet PC"
    By PiperTim in forum Android 4.0 Ice Cream Sandwich
    Last Post: 02-06-2014, 04:40 PM
  4. Access Words with Friends Files?
    By BodaciousE in forum HTC One X
    Last Post: 02-06-2014, 01:41 PM
  5. contact prediction
    By 13iron in forum General Help and How To
    Last Post: 02-06-2014, 01:09 PM
