Results 1 to 8 of 8
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Prepping rooted Note 3 for Kit Kat
    I rooted my Verizon device using TWRP.
    Should I just wait and sideload KK when it becomes available (assuming that I don't need to upgrade with what's currently available and want to wait until the Verizon/US version gets out)?
    Or should I unroot back to stock first and OTA it?
    Or can I simply reinstall my stock ROM in recovery and OTA?
    I used to have Save Root. It worked like a charm for my Motorola devices. Does this work between updates as well? Do we know yet if there will be a way to save root when upgrading?
    So many questions...
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Prepping rooted Note 3 for Kit Kat
    You can make a nandroid backup now, and flash a custom ROM. Then come back to the nandroid when the OTA is out and flash a stock firmware (Done in download mode, not recovery)
    Not sure about save root but OTAs typically break root for Samsung phones, if you can even get the phone to take it while rooted
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How do I get to download mode? Every time I try to do it, I end up straight into recovery mode.
    Sent from my SM-N900V using Tapatalk
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Plus, I'm trying to remember but I think that doing an OTA with Motorola also broke root but Save Root could bring it back. Don't quote me on that though. I seem to remember doing the OTA with my RAZR and using Save Root to bring it back but I could be wrong about that.
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Quote Originally Posted by teleburst View Post
    Download mode is the same button combo as recovery, but instead of volume up, you use volume down
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ahhh, thanks!
    This method is something that I need to use Odin for, right? I haven't had to use it for anything yet.
    anon24860's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If I have my stock ROM saved in the stock slot in TWRP, that's my Nandroid, right?
  8. #8
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Ahhh, thanks!
    Yeah, stock firmware can only be flashed with Odin and using DL mode. It might come in handy later on. Odin is a life saver
  1. Should I return my Note 3?
    By ImStevo in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-28-2014, 09:38 AM
  2. T-Mobile Note 3 google nav fails.
    By Android Mafia in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 02-14-2014, 12:18 AM
  3. Is there a camera mod for non rooted users?
    By darryjr in forum Sprint LG G2
    Last Post: 02-07-2014, 06:19 PM
  4. How hard is rooting? I want to but scared
    By xxventanaxx in forum General Help and How To
    Last Post: 02-07-2014, 02:13 PM
