1. monsow's Avatar
    Hey guys!
    I've recently read a lot of articles stating that killing apps in Android is bad, because the Android OS handles this task automatically. This supposedly uses more battery, because Androis has to use power in opening that app from scratch each time.
    I've thus decided not to kill apps manucally. I only have one question, is the "Task Killer" from Battery Doctor actually killing the apps? They still appear in the recently used apps after I've pressed the Task Killer widget.
    I am running 4.4.2 on Nexus 5 btw.
    Thanks in advance!!
    02-08-2014 04:00 PM
  2. EviI's Avatar
    Hey guys!
    Thanks in advance!!
    You can check if they're still running by going to Settings > Apps and then switching to the Running tab.
    02-08-2014 04:49 PM
  1. Battery draining faster with Spark
    By Robynsnest in forum Sprint LG G2
    Last Post: 02-12-2014, 04:40 PM
  2. S3 mini with S3 (2100 mAh) or Ace3 (1800 mAh) battery?
    By Qrczak in forum Samsung Galaxy S3 Mini
    Last Post: 02-09-2014, 10:05 AM
  3. ZTE Valet short battery life due to wifi?
    By HalOfBorg in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-09-2014, 08:32 AM
  4. Opera Browser Huge Battery Drain on Samsung Galaxy Note 3
    By nayan350 in forum Samsung Galaxy Note 3
    Last Post: 02-09-2014, 02:46 AM
  5. Davlik vs Art battery life
    By cappy718 in forum Moto X (2013)
    Last Post: 02-08-2014, 02:30 PM
