Zooper Widget and Media Utilities Problem
yoyokid8
12
Every time I try to upload a Media Utilities\Zooper Widget (made by myself or pre installed on Google Play), it never works. This shows up:
I know all the widgets are basically programmed the same way, #TMU_ARTIST#, and etc. for the other stuff, but it never works. Help!
Sent from my Nexus 7 using Tapatalk
I know it's broken on android L.
On other versions go into Media utilities and click settings then near the bottom select zooper and make cover art available.
cotogon222
