1. TomBrooklyn's Avatar
    Nexus 7 (2nd Gen)
    How do I organize my icons? How do I move them?
    I've got icons all over the place is seemingly random locations, with no apparent way to move them.
    EDIT: Added my device information
    02-11-2014 04:14 AM
  2. Slaytor Z's Avatar
    Tap and hold on an app or widget. Keep holding it and you can move them around. On most devices flicking up will remove the app/ widget from the homepage and moving it to the left or right edge of the screen will move it to the next homepage. Once you let go, the app/ widget will lock in to it's new place.
    Depending on what device you have, you can only move the icons on the homepage. Nexus and pure Android flavour devices can't change the order of apps in the app drawer, whereas OEMs with custom skins like Samsung, Sony, HTC and LG allow them to change.
    srkmagnus likes this.
    02-11-2014 05:18 AM
  3. srkmagnus's Avatar
    Also, moving an icon over another usually will create a folder. This is useful to not clutter the screen and have your Apps neatly organized for quick access.
    02-11-2014 09:00 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! May I suggest this guide: http://forums.androidcentral.com/gen...14-part-i.html
    02-11-2014 12:14 PM
  5. TomBrooklyn's Avatar
    OK. I got them moving around now.
    On most devices flicking up will remove the app/ widget from the homepage and moving it to the left or right edge of the screen will move it to the next homepage. .
    OK. I removed an app, and I got one to move to the next page. These several pages are all called homepages, I take it.
    Is the app drawer the place arrived at by pressing the white circle with 2 rows of 3 white dots in it?
    02-16-2014 09:04 AM
  6. TomBrooklyn's Avatar
    Thank you. OK. I've spent some time looking at that; and I'll continue to check it out.
    02-16-2014 09:05 AM
  7. Slaytor Z's Avatar
    That's right. It shows all your apps and widgets.
    02-16-2014 09:32 AM
  1. How Show Seconds On Home Page Clock?
    By TomBrooklyn in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-16-2014, 07:04 AM
  2. How do I upload pictures into AC forums
    By longtime44 in forum General News & Discussion
    Last Post: 02-11-2014, 11:37 AM
  3. Which Android App should install in my Phone?
    By VelmaNichols in forum Android Apps
    Last Post: 02-11-2014, 05:45 AM
  4. Replies: 2
    Last Post: 02-11-2014, 05:04 AM
