1. TomBrooklyn's Avatar
    Where is this thing called Settings?
    I've been instructed by various sources to do something in the Settings; with no clue given as to what the Settings is, where to find it, or even what it looks like.
    02-11-2014 04:16 AM
  2. mrsmumbles's Avatar
    It looks like a round gear. On this screenshot it's in the 3rd row on the right. You should be able to find it in your app drawer.
    Edit: I should say, it's in the top row on the right.
    Sent from my Nexus 5 using Tapatalk 2
    Attached Thumbnails Where Is the Settings?-uploadfromtaptalk1392114277787.jpg
    srkmagnus likes this.
    02-11-2014 04:24 AM
  3. Slaytor Z's Avatar
    Also swipe down from the top edge of the screen - nearly all Android phones have the settings button there (notification shade). It's a handy shortcut so you can access settings from within almost any app.
    mrsmumbles and srkmagnus like this.
    02-11-2014 05:43 AM
  4. srkmagnus's Avatar
    What phone do you have? Settings is accessed by pressing menu on the home screen or by following the instructions provided above. Let us know if you need further help.
    mrsmumbles likes this.
    02-11-2014 08:56 AM
  5. B. Diddy's Avatar
    02-11-2014 12:17 PM
  6. TomBrooklyn's Avatar
    OK. I found the gear on the last page of my apps. Thanks.
    I have a Nexus 7 tablet, not a phone.
    02-16-2014 08:55 AM
  1. Replies: 2
    Last Post: 02-21-2014, 02:56 AM
  2. Note 3 kitkat in the UK
    By mattyt1 in forum Samsung Galaxy Note 3
    Last Post: 02-11-2014, 10:44 AM
  3. [free game] : Spot the brand
    By ThemeBowlApp in forum Android Games
    Last Post: 02-11-2014, 09:48 AM
  4. Replies: 2
    Last Post: 02-11-2014, 05:04 AM
  5. Replies: 0
    Last Post: 02-11-2014, 12:55 AM
