1. justin4408's Avatar
    Hello all,
    I was just wondering if anyone had any experience with this following problem:
    I dropped my phone that created a crack (a new crack stemming from an older one which gave me no problems) which lead to me not being able to use the very bottom of my screen (really just the space bar area). The crack was slightly above said area. Then this "blue ink" smudge began forming and took over the bottom 1/4 inch of the screen. When I woke up the next morning, the only portion of the screen still visible was the middle third, as the top and bottom were now dark blue. By the end of my shift that morning, the screen was completely black. I have heard a screen replacement may be all I need, but I am worried that the digitizer (I hope I'm using the right terminology, referring to the touch screen capability of the phone) may have been damaged as again I could not use the bottom part of my screen. Any info or tips would be greatly appreciated.
    Thank you for your time, everybody.
    02-12-2014 05:43 PM
  2. justin4408's Avatar
    Fist bump
    02-12-2014 06:55 PM
  3. Rukbat's Avatar
    You need a new LCD, that's for sure. If the screen doesn't respond to touch you need a new digitizer as well.
    02-12-2014 08:48 PM
  1. Photo sync with two G+ accounts on one phone?
    By Cigar-Junkie in forum Samsung Galaxy S4
    Last Post: 06-05-2015, 09:57 AM
  2. Wifi problems with dual band router
    By recDNA in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-15-2014, 10:03 AM
  3. [APP][FREE] MemoCool - Notes with personality
    By Naladex in forum Android Apps
    Last Post: 02-13-2014, 10:04 AM
  4. Touch Screen Becoming Intermittently Unresponsive
    By PAC757 in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-12-2014, 04:35 PM
  5. Unwanted Blue Border Surrounding Screen
    By johnnysporto in forum HTC One M7
    Last Post: 02-12-2014, 12:31 PM
