Results 1 to 6 of 6
    Default Help! Galaxy Note 10.1 Connecting to Tv with Wired Adapter
    I just purchased an RCA audio/video adapter for my Galaxy Note 10.1, but I can't get the video to work. The audio comes through to the TV, but nothing on the video. Is there a setting that needs to be changed in the tablet? I hope to use it for slideshows on projectors as well as videos. The cable was purchased on Ebay as a genuine Samsung cable in new condition. Thank you for the help!
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: Help! Galaxy Note 10.1 Connecting to Tv with Wired Adapter
    HDMI cable? Composite cable? RGB cable? S-Video cable?
    Specifically, "New Samsung TV-Out Composite AV Video Cable for Galaxy Tab and Samsung Tablets" listed on ebay: New Samsung TV Out Composite AV Video Cable for Galaxy Tab and Samsung Tablets | eBay
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    That would have to be plugged into your Composite and audio inputs on the TV. Are you sure you get the plugs in the right places? The fact that a plug fits a jack soesn't mean that it's in the rght jack. All RGB and composite connections use the same connectors, but they can't be interchanged.
    You're getting audio, so the red (right) and white(left) cables seem to be plugged into the correct jacks. Is the yellow plug plugged into the composite video jack? And is the TV Source set to Composite Video?
    Yes, I have tried both the composite and the RGB on two separate TVs. It seems to be either the cable or the tablet. I'm wondering if my tablet even supports video output, but I haven't been able to find any documentation one way or the other.
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    It most likely doesn't support composite video - that's about 1946 technology. TV sets support it because the circuitry is already there, so all it costs is a 3 cent jack and about 0.01 cents of labor. Try MHL - you can probably find a decent adapter for about $10-$30 on Amazon. (An HDMI cable will cost you another $2-$5.)
  1. do the stickers on the back start to becoming loose?
    By preppystud in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-14-2014, 03:29 AM
  2. Moving to France and Need Help with Frequencies and Phones
    By brymo in forum General Help and How To
    Last Post: 02-13-2014, 08:15 PM
  3. Samsung galaxy s3 screen problems (probably software)
    By Eldon River in forum Samsung Galaxy S3
    Last Post: 02-13-2014, 06:21 PM
  4. galaxy problem
    By bagasrawala in forum Samsung Galaxy Grand
    Last Post: 02-13-2014, 10:43 AM
  5. Please help me! Problem with 4.3update on S3
    By Eme twyuan in forum Samsung Galaxy S3
    Last Post: 02-13-2014, 08:16 AM
