1. Nav12345's Avatar
    Samsung i9505 Galaxy S4 LTE 32GB (Unlocked) (White Frost)
    Hi i really want a 32gb s4, and ive found one hear, but Ive read reviews saying its imported from china as the 32gb isnt availabler anywhere else. Could this be a fake device and/or would it work in the Uk 3g and 4g????? If not to any then does anyone know where i can get a legit 32gb version of the phone(in white)
    thanks, will really realllyyy appreciate some help
    02-14-2014 01:36 PM
  2. someguy01234's Avatar
    NegriElectronics is a large importer, they are a legitimate business so you shouldn't worry buying from them. That item is not in stock though.
    02-14-2014 02:06 PM
  3. Nav12345's Avatar
    Hi, but would it work in the Uk on a tmobile 3G as its not intended for anything other than china, also could it be fake??:s
    02-15-2014 08:07 AM
  4. UJ95x's Avatar
    You can check the network compatibility here: http://www.morecellphone.com/phone/s...i9505-32gb/824
    See which bands your carrier supports so you know if you'll get 3G where you live
    Sent from my Galaxy S4 running Slim Bean 4.3
    02-15-2014 08:37 AM
  5. Nav12345's Avatar
    You can check the network compatibility here: Samsung Galaxy S4 LTE GT-i9505 32GB - Full specifications, specs - More Cell Phone
    Hi thanks for the help but i dont really know how to interpret this..
    02-15-2014 10:13 AM
  6. UJ95x's Avatar
    Check which bands your carrier supports. Then see if they match up with the bands shown in the link I gave you. All you're doing is checking if they are supported
    02-16-2014 12:57 AM
  7. Nav12345's Avatar
    Ok so i think it is, with the 2100 frequency but not the 1700 frequency..does the i9505 16gb have different network frquencies to the 32gb? and the link i posted for negri elctronics, I know that device is from china so will the actual phone be in chinese or will i be able to set it to english etc n is it legit(not fake)? Plus would It be returnable if it turned out it couldnt work? Thanks!!
    02-16-2014 09:46 AM
  8. UJ95x's Avatar
    Both the 16 and 32 GB have the same band compatibility.
    It won't be in any preset language, you choose that when it first boots up
    Idk about Negri's return policies so you'll have to check on their site
    02-16-2014 02:25 PM
  9. Nav12345's Avatar
    Hi thank youu! so What is is the difference between them seeing as this ones being importedbfrom china?
    02-16-2014 06:21 PM
  10. UJ95x's Avatar
    I don't think there is a difference. The i9505 is the international version, but it's not locked to a certain country or carrier. It's used across the world depending in its compatibility with the carrier's bands
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-16-2014 06:53 PM
  1. How do I revert to stock S4 OS from CyanogenMod
    By Stellaellabella in forum Other OS's and Devices
    Last Post: 03-06-2015, 02:49 PM
  2. Replies: 3
    Last Post: 03-06-2014, 02:33 PM
  3. Samsung galaxy s3mini shows grey screen
    By phoebus_apollo in forum Samsung Galaxy S3 Mini
    Last Post: 02-14-2014, 11:40 PM
  4. Please help me with this decision
    By Spicey-Ryan in forum HTC One M7
    Last Post: 02-14-2014, 04:35 PM
  5. Is my charger going bad?
    By stackberry369 in forum General News & Discussion
    Last Post: 02-14-2014, 12:38 PM
