Can I get contacts information from web to Android phone book without manually typing?
Largg
5
Hello all
Isn't there a way I can get contact information I find on the web into my Android phone book without having to pull out my phone and typing it in by hand?
I thought there was a way, maybe I had to add something to my computer where I could type highlight the name, address and phone number, right click up a menu and have it all added to my phone book.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,592
4,732
113
Welcome to Android Central! The easiest way I can think of is to enter that contact info into your Google Contacts on the web. It will then sync to your phone.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,592
4,732
113
You might try this extension for desktop Chrome: Evercontact. This will let you grab contact info from the web and blow it into Google Contacts. From there, it should sync to your phone.
akbarramadhani12
