1. Filip Pajic's Avatar
    I bought tablet GoClever Terra 72 7 days ago and my battery was dead and i put it on the charger last night and now it wont turn on.
    I don't have volume buttons to enter a recovery mode, i can't access tablet with computer, when i put it on the charger or usb it become heat up.
    I can not get the screws out because it is under warranty.
    If anyone have solution plase tell me.
    Sorry for my bad English!
    02-15-2014 05:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does the tablet have a pinhole reset button anywhere? If you see one, try pressing it with a paper clip or safety pin, keeping it down for about 10 seconds.
    02-15-2014 11:55 AM
  3. Filip Pajic's Avatar
    I think i found pinhole reset button on the rear of the tablet, pressed it for about 10 sec and nothing happend.
    02-15-2014 05:15 PM
  4. B. Diddy's Avatar
    How long did the tablet remain off charger after it shut off? There's a possibility that the battery was allowed to discharge completely, which can irreversibly kill the battery.
    02-15-2014 05:31 PM
  5. Filip Pajic's Avatar
    I think that battery is pretty much dead, but when i plug it into charger it heat up pretty bad
    02-15-2014 05:33 PM
  6. Alan Peterlin's Avatar
    yes it hapened the same to me on goclever tablet.I tried to refill the tablet but the power was always 15 percent.Once then i tried to empty the power at all.But then the pkwer was 0 percent.I only could play it if it was constantly on charger.When i plugged it off the tablet gurned off.Today when i came home from grandma it didnt wanted to turn on at all.so can someone help me?
    06-10-2014 01:04 PM
  7. B. Diddy's Avatar
    As with the above posts, I would suspect a dead or faulty battery. Or possibly defective hardware. There will always be more chance of hardware defects with these lesser known brands. Try to contact the manufacturer's tech support for possible return or repair.
    Posted via Android Central App.
    Please excuse any typos or autocorrect derps.
    Alan Peterlin likes this.
    06-10-2014 01:43 PM
  8. Alan Peterlin's Avatar
    THANKS!!!
    06-11-2014 03:34 AM
  9. Rukbat's Avatar
    If a lithium ion battery is completely dead (not just 0 charge but completely dead, which is almost impossible), and you charge it, one of two things will happen. Either it will get so hot that it will burst into flames, or it will get even hotter faster and explode. So lithium ion batteries have a little circuit inside, like reverse fuse, that "blows" if the battery discharges too far. That makes the battery a paper weight, and it has to be replaced.
    Filip, in your case, the battery probably got discharged so far that, although the "fuse" didn't disconnect the battery inside, the battery is still just turning most of the charging power into heat. It has to be replaced. The problem is that the cost of the battery and the labor to replace it (batteries usually aren't covered under warranty) is probably more than the price of a new tablet in the case of these cheap tablets.
    B. Diddy likes this.
    06-11-2014 10:56 PM
  10. Alan Peterlin's Avatar
    My tablet just went to poland servis few days ago...It will be back in a month or two.Thanks everyone fpr your support.
    06-22-2014 03:17 PM
  11. Alvic's Avatar
    Hi B. Diddy, I also have the same problem with a GoClever Terra and wish to send it to the manufacturer, still on warranty. Can you tell me if yours got repaired and where did you send it to? Please provide me with an address if possible. Thanks in advance.
    12-08-2015 07:50 AM
  1. Lost S memos on update!
    By 79diz in forum Samsung Galaxy S4
    Last Post: 06-02-2015, 02:37 PM
  2. Burn in on IPS display?
    By brandonx1000 in forum Verizon LG G2
    Last Post: 02-16-2014, 08:06 PM
  3. Battery level notification on active display
    By stevewhite71 in forum Moto X (2013)
    Last Post: 02-15-2014, 02:37 PM
  4. Use android tablet as game controller for PC?
    By barth2 in forum General Help and How To
    Last Post: 02-15-2014, 01:28 AM
  5. Replies: 1
    Last Post: 02-14-2014, 11:30 PM
