1. spiderbatman's Avatar
    Hi,
    I have a Asus Transformer TF701. I was using it and it was out of power. So I plugged it in and now it is stuck at boot up.
    Even if I force it to shutdown (long press power button) it again starts and gets stuck at boot up.
    I need help desperately as to how can I resolve this problem. Please help.
    Thanks in advance.
    02-15-2014 11:05 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! After powering down, try powering up again by pressing and holding the Power and Volume Up buttons--keep them down until some kind of recovery menu appears. If that doesn't work, try Power and Volume Down.
    02-15-2014 01:36 PM
  3. AndroidProf's Avatar
    Let me elaborate on that, this will open the bootloader menu. Once in that menu, look for the option that says "Factory Reset" and a "Wipe Cache" option. You can navigate the menu by pressing the volume keys. Also, do remember by doing this you will be wiping your Asus Transformer CLEAR of all personal data that is stored in the internal memory of the tablet! If that doesn't help and you are still stuck in a bootloop, I'm sorry to say but then you will have to flash in a new ROM on your device. For that you will need a custom recovery (I suggest TWRP, you can Google TWRP and go to the first link and just find the recovery for your device, they even teach you how to install the recovery). Once you have done that, you can find a custom ROM for your device or even the factory image online on XDA developers, Clockwork Mod, CyanogenMod or searching for the factory image (the default ROM). You can download the ROM and flash in via the custom Recovery by going to the bootloader again (Restart while holding Vol. Down) Then selecting Go to Recovery Menu (pressing Power + Vol Up once the exclamation sign appears, alternatively if you have any experience with how to use adb you can simply use "adb reboot recovery" as well). From there, simply flash in the ROM from the "Install via .zip file".
    B. Diddy and spiderbatman like this.
    02-15-2014 01:43 PM
  4. spiderbatman's Avatar
    Thanks a lot. Bringing it back to factory settings worked fine. I didn't had to flash it..
    02-16-2014 05:19 PM
  1. how to get pics and videos out when am stuck in samsung logo
    By Khalid Al Ghamdi in forum Samsung Galaxy S3
    Last Post: 03-16-2014, 12:35 PM
  2. help HTC one bought it fairly used
    By Osuagwu Darlington in forum HTC One M7
    Last Post: 02-17-2014, 01:29 PM
  3. tasker help
    By gillbie943 in forum General Help and How To
    Last Post: 02-16-2014, 07:14 AM
  4. how to get pics and videos out when am stuck in samsung logo
    Last Post: 02-15-2014, 11:52 AM
  5. What am i to do with this? please help!
    By marktika in forum Samsung Galaxy Note 3
    Last Post: 02-15-2014, 10:23 AM
