Low battery alert
wardawgmalvicious
Active member
Feb 13, 2014
39
Anyone know how to disable the low battery alert audio? I have disabled the popup, but I would like to also disable the audio. I tried deleting the lowbattery.ogg file in the root media file, but then it just played a different audio file for the low battery. Any ideas? I am on a rooted Nexus 5 running 4.4.2
Sent from my Nexus 5 using Tapatalk
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,365
110
63
Yes, it can be found with Xposed framework, with Gravity box and under power tweaks.
wardawgmalvicious
Active member
Feb 13, 2014
39
Yep I found it, amazing app/module it is. I had been using Wanam Kit. Well I still use Wanam Kit for a few things, but GB has just everything in one.
