1. wardawgmalvicious's Avatar
    Anyone know how to disable the low battery alert audio? I have disabled the popup, but I would like to also disable the audio. I tried deleting the lowbattery.ogg file in the root media file, but then it just played a different audio file for the low battery. Any ideas? I am on a rooted Nexus 5 running 4.4.2
    Sent from my Nexus 5 using Tapatalk
    02-17-2014 06:21 PM
  2. wardawgmalvicious's Avatar
    Gravity Box
    02-18-2014 05:37 PM
  3. Golfdriver97's Avatar
    Yes, it can be found with Xposed framework, with Gravity box and under power tweaks.
    02-18-2014 05:53 PM
  4. wardawgmalvicious's Avatar
    Yep I found it, amazing app/module it is. I had been using Wanam Kit. Well I still use Wanam Kit for a few things, but GB has just everything in one.
    02-18-2014 06:46 PM
  1. Replies: 33
    Last Post: 07-07-2015, 02:21 PM
  2. Firmware Upgrade Error - Low Battery Error
    By jerky1280 in forum AT&T Galaxy S II
    Last Post: 07-15-2014, 01:01 PM
  3. Verizon Note 3: Google Services/Battery Life
    By bertsirkin in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-31-2014, 07:10 AM
  4. Battery Life
    By Justin Cardwell in forum Sprint LG G2
    Last Post: 02-17-2014, 06:43 PM
  5. When is Zerolemon releasing a battery for S4 Mini?
    By Shelter7 in forum Samsung Galaxy S4 Mini
    Last Post: 02-17-2014, 01:24 PM
