1. CarnCarnage's Avatar
    I rooted a Huawei H866C and it was working fine, no issues.
    I am getting ready to give the phone away, and decide to do a Factory Reset.
    Now the phone is stuck on the initial Tutorial Section, where it gives you the option to select language, etc.
    Every time I press "Begin", it errors out and states that StartupWizardEX has stopped responding and needs to close.
    I tried to boot into recovery mode and do another Factory Reset, issue still persists.
    I didn't touch the Bootloader or load any odd software into it. I did remove some "safe" bloatware, but nothing that would have changed the normal operation of the phone.
    Is there any way to bypass the initial Tutorial section, or any other simple fix for this? It's a useless section and I really need to hand this phone off soon.
    02-19-2014 10:32 AM
  1. 4.3 Problems - Airave?
    By elshagon in forum HTC EVO 4G LTE
    Last Post: 03-10-2014, 06:44 PM
  2. Is hard reset really necessary for update?
    By SandroidE in forum Moto X (2013)
    Last Post: 02-19-2014, 11:48 AM
  3. Having problem with Hands Free mode and bluetooth...
    By restockton in forum Sprint Galaxy S III
    Last Post: 02-19-2014, 09:39 AM
  4. Replies: 0
    Last Post: 02-19-2014, 08:43 AM
  5. huawei g525
    By Ahmad Eshgevaryan in forum Huawei
    Last Post: 02-19-2014, 05:55 AM
