Results 1 to 3 of 3
    moorejrjr's Avatar
    Posts
    Global Posts
    20 Global Posts
    Default Is there a way to crop homescreen widgets?
    I use Nova launcher. I am on a moto X inches btw. I'm not tied strongly t move launcher.
    Basically, I want to crop widgets like the Google keep widget (u only need quick keep text not the list picture etc) and other widgets. Is there a launcher or a way to do this? I can resize them, but I'd like to crop them
    Thanks!
  2. #2
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Default re: Is there a way to crop homescreen widgets?
    As far as I know, no launchers currently on the Play Store offer control over how widgets adapt to being resized. Launchers can do things like scaling and rotating of items on the homescreen (Lightning Launcher does this, for example) but I do not believe they can control the layout within an individual AppWidget:
    The behavior of an app widget is published by an "app widget provider." An "app widget host" is a component that can contain app widgets (such as the home screen).
    The "provider" is a part of the same app that has the widget in question (i.e. Google Keep). This specifies the behavior of the widget, which includes any necessary layout work. The launcher (i.e. Nova Launcher) acts as the "host." It is able to embed other apps' AppWidgets inside itself, but cannot directly control them. Unfortunately, I couldn't find any other launchers or modifications (such as an Xposed module) that would allow you to do this.
    moorejrjr likes this.
    moorejrjr's Avatar
    Posts
    Global Posts
    20 Global Posts
    Default Re: Is there a way to crop homescreen widgets?
    Thanks for your response!
    I'm somewhat surprised there is no way to crop apps, given the amount of customization available on the Android platform. Hopefully someone eventually figures it out.
    Thanks again!
  1. Will it be possible to root the Verizon's Samsung Galaxy S5?
    By yourphonemyphone in forum Samsung Galaxy S5
    Last Post: 02-24-2014, 05:39 PM
  2. get around Knox to root
    By jemalone in forum Samsung SAFE and KNOX
    Last Post: 02-24-2014, 07:16 AM
  3. [FREE] My dinosaur game is over 100 000 downloads!
    By Darie_P in forum Android Games
    Last Post: 02-21-2014, 10:55 AM
  4. Facility to search device content on note8?
    By incrimsonrose in forum Samsung Galaxy Note 8.0
    Last Post: 02-20-2014, 06:02 PM
  5. Crop widgets?
    By moorejrjr in forum Android 4.4 KitKat
    Last Post: 02-20-2014, 12:09 PM
