1. ccorbos's Avatar
    Hey guys , so i got a brand new S3 In december 2013 , i dropped it an it broke ( both touch and LCD ) I got them replaced by a authorized service . It worked fine 2 months , Two days ago some problem appeared, Touch screen stopped working propperly , it worked only for short periods of time. Now if i press really hard on the right hand corner (Above the return arrow) it works Perfectly ( as long as i keep my finger there) but sometimes it works fine after reboot but in the end it stops (No signs of cracks or damage) , i had CM11.
    What i've done until now :
    -Deleted CM11 and added 4.1.2
    -Took it appart and checked the ribbon ( fine)
    -Hard reset
    - Dummy file generator
    P.s : Everything works on it buttons , volume rockers ..
    P.p.s for more info ask me , thak you very much
    P.p.p.s Before the freezing screen flashes a bit .
    02-20-2014 01:51 PM
  2. UJ95x's Avatar
    Welcome to Android Central
    This is a hardware issue. If you dropped it and it stopped working properly, you're going to have to get it replaced again
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-20-2014 01:57 PM
  3. ccorbos's Avatar
    I forgot to say that i freezes a lot , like a lot a lot, i checked the insides and i couldn't spot any damage...
    02-20-2014 02:18 PM
  4. Rukbat's Avatar
    If the problem just "appeared" (you didn't drop it again, or something), it should be under warranty for 90 days, so try bringing it back. (Check your paperwork first, though - some shops only warranty parts for 30 days. Some only warranty for 30 days - parts, labor, everything.)
    02-20-2014 07:15 PM
  1. Kyocera Event trouble - Help!!!
    By Princess Prettypants in forum Android 4.0 Ice Cream Sandwich
    Last Post: 02-17-2015, 07:56 PM
  2. Replies: 6
    Last Post: 12-09-2014, 09:32 PM
  3. Twitter SMS Help?
    By FutureKix in forum General Help and How To
    Last Post: 02-20-2014, 01:10 PM
  4. Having trouble with Youtube app, please help!
    By anon8556802 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-20-2014, 11:16 AM
  5. Galaxy S4, running latest android, stuck in recovery mode - help please
    By Lashenko in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-20-2014, 11:01 AM
