Results 1 to 4 of 4
Like Tree4Likes
  • 3 Post By Paul627g
  • 1 Post By Patrick Schroedl
    Celina1717's Avatar
    Posts
    Global Posts
    2 Global Posts
    Default
    Hi just bought a Samsung galaxy s3 and it has water damage it is currently in rice however the problem with it is tht it just keeps restarting. Everything else on the phone works fine... anyone have any idea what the problem may be?
  2. #2
    Default Re: help
    Water damage...
    Water damage is completely unpredictable what it will damage within a device. Even doing the rice treatment its no guarantee.
  3. #3
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,828 Global Posts
    Default Re: help
    As Paul said, the effects of water damage can be unpredictable, and are often difficult (or impossible) to fix yourself. If the water damage occurred before you bought the device, there may be no way to restore it to a working state. Depending on where you bought it you may be able to take the issue up with them, though if you purchased it directly from the previous owner you may out of luck.
    srkmagnus likes this.
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,688 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: help
    I am also in agreement with these guys. Until you decide on what to do it maybe worthwhile to turn off the device for a few days with the battery removed. After a few days reinsert the battery and let it charge and try and start it. See if that help after its had time to fully dry - it's a long shot but worth a try.
  1. already got the 8.4... I just cannot help myself, so I ordered the 10.1 also!
    By angry english in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 02-21-2014, 08:28 AM
  2. HELP!! Switching from Iphone 4s to Android - Need phone recommendations
    By laura1fresitas in forum General Help and How To
    Last Post: 02-20-2014, 10:00 PM
  3. Please help with sgs3
    By ccorbos in forum General Help and How To
    Last Post: 02-20-2014, 08:15 PM
  4. **Help** Facebook Video: Sound but no video
    By DavidTorres1989 in forum Samsung Galaxy S4
    Last Post: 02-20-2014, 07:04 PM
  5. Help! Note 2 bootloop no recovery
    By MBrar15 in forum Samsung Galaxy Note 2
    Last Post: 02-20-2014, 05:19 PM
