1. Mindzata's Avatar
    Hello all,
    I just bought an X Cover 2 and I love it. There is just one small irritation for me. When I carry it in my pocket and somebody rings 50% of the time the phone cancels the call on its own. I'm guessing it is because it has a very sensitive touchscreen (really a lot more sensitive compared to my old Nexus One). So is there a way to make the phone answer calls only with the lock screen pattern?
    Thank you
    02-21-2014 07:32 AM
  2. srkmagnus's Avatar
    I think you can enable the lock screen password and it will require you to enter it when answering a call. I don't use the security features so can't say for sure.
    02-21-2014 03:07 PM
  3. Mindzata's Avatar
    Sadly, no. I have enabled the lock screen pattern, again because my phone kept unlocking in my pocket and turning on WiFi etc. But even now the answer call is still only with a sweep of the screen.
    02-22-2014 02:26 AM
  4. Cris Frasineanu's Avatar
    Hi, have you found a solution? I have the same problem.
    05-29-2015 09:16 AM
  1. A solution to one cause of android.process.acore stopped working
    By Guinness2702 in forum T-Mobile HTC Sensation
    Last Post: 03-12-2017, 11:53 PM
  2. Strange Issue(Auto Touch) with Touch on HTC Desire X
    By khaledbenjannet in forum HTC Desire
    Last Post: 05-24-2015, 08:55 AM
  3. emails not staying on phone
    By mtvictor in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-21-2014, 02:27 PM
  4. Replies: 1
    Last Post: 02-21-2014, 08:16 AM
