1. L Ahmed's Avatar
    All my pictures and videos got deleted from my android phone somehow, and now my sd card is not being recognised by my phone. I am also unable to unmount or format my sd card to get it to work. What should I do?
    02-21-2014 05:42 PM
  2. Rukbat's Avatar
    What make card? How large? What make and model phone? (When you turn the phone off the card is automatically unmounted, When you turn the phone on the card is automatically mounted. So if you want to try the card in a computer, turn the phone off and remove the card.)
    02-22-2014 06:25 PM
  3. Santhosh Kumar20's Avatar
    i can not format the sd card
    11-04-2014 01:52 AM
  4. Rukbat's Avatar
    If a card won't format in a device (phone, tab or computer) that can format other cards, it's most likely a bad card. You can save money when you buy the card or you can buy a SanDisk and not have problems they won't take care of.
    11-04-2014 05:17 PM
  1. FoxFi/Free Wifi on the Verizon Note 3
    By SancLunatic in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-28-2014, 09:56 AM
  2. How to sync contacts from my Microsoft exchange account
    By narcomano in forum AT&T Galaxy S III
    Last Post: 02-28-2014, 07:07 PM
  3. What causes Android phones to lag over time?
    By jackadillo in forum General News & Discussion
    Last Post: 02-24-2014, 09:30 AM
  4. Verizon phone on T-Mobile
    By Froalskiner#WN in forum T-Mobile
    Last Post: 02-23-2014, 09:52 PM
  5. Replies: 1
    Last Post: 02-21-2014, 05:01 PM
