Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Rukbat
    brown_owl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can't send or receive picture messages?
    I searched some other threads on the subject, but couldn't find an answer, so sorry if this is a duplicate thread.
    I can send and receive normal texts, but not pictures. When I try to send a picture, it says "Message not sent." "MMS not supported by network." "Server response error." And when someone tries to send me a picture, I was directed to a website called viewmymessage.com.
    I have a Samsung Galaxy s3 with AT&T. Any ideas? Thanks.
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,818 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can't send or receive picture messages?
    Welcome to Android Central! Are you using the messaging app that came with the phone, or Hangouts, or some other messaging app? Also, MMS requires your mobile data (3G or 4G) to be on--it doesn't work over wifi or the voice line. Are you sure your mobile data is on?
    brown_owl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am using the messaging app that came with the phone. And mobile data is on.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    77,818 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    And you're able to access other parts of the web with your mobile data, correct? Just need to make sure there isn't any network problem in your area. I'd suggest calling AT&T and seeing if there's a problem they're aware of.
    brown_owl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I can access everything else with my mobile data. Just having trouble with picture messages. I will call AT&T tomorrow. Do you think switching to another messaging app would help?
  6. #6
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    It sounds as if your MMS data is set up wrong. Switching to another app wouldn't make any difference. But any AT&T DSC should be able to fix the problem in a couple of minutes.
    ManiacJoe likes this.
  7. #7
    Julie Thorogood's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can't send mms as I get message saying server error and not connected to network when I am.
  1. Cannot unmount or format my sd card on my phone
    By L Ahmed in forum General Help and How To
    Last Post: 11-04-2014, 05:17 PM
  2. Nexus 5: Unwanted Pictures
    By bembol in forum Google Nexus 5
    Last Post: 02-24-2014, 06:16 PM
  3. How can I unroot my Note 10.1 2014 so that I can get OTA updates?
    By aaka3207 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-23-2014, 10:12 AM
  4. Location History points seperation by IMEI or phone number
    By mcjurys in forum General News & Discussion
    Last Post: 02-21-2014, 05:41 PM
  5. Replies: 1
    Last Post: 02-21-2014, 05:01 PM
