Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Golfdriver97
    wolfhead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Rom question .
    As of yet I have not heard of any roms compatible to flash for the rooted Kyocera hydro C5170.
    Therefore having to keep stock rom could you still tweak it a little such as changing the fonts or theme without any harm to the stock rom. If anyone is familiar with this specific device I would highly appreciate your help. Thanks !
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,058 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Rom question .
    In general, changing the fonts shouldn't be all that bad. But it may be possible that it might have some negative effects. Are you rooted?
    wolfhead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I'm rooted. Thanks for the reply. Not sure I'm gonna attempt it.
    Figure any attempt to tweak the stock rom may screw it up.
    As I had said there's no other roms yet for this device.
  4. #4
    Posts
    Global Posts
    33,058 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Since you are rooted, a better option may be Xposed framework.
    From a Sprint Moto X using AC Forums app
    srkmagnus likes this.
  5. #5
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Fonts, themes and launchers aren't tweaking the ROM, they're things the ROM is written to allow.
  6. #6
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    When you rooted were you able to install a custom recovery, such as cwm or TWRP? If so, be sure to backup the current ROM before you start playing with the existing one. This way you can restore the working ROM if you have problems with the phone after installing a mod or tweak.
    wolfhead's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I backed up everything ! Since I know there's no ROMS for my device I seen some people with same device who had tweaked somethings and suddenly was either bricked or experienced problems. So before I attempt any tweaks I try being cautious.
    Thanks for the help !
  1. Verizon: Google Wallet Question
    By cb2367 in forum Verizon
    Last Post: 02-24-2014, 01:35 AM
  2. Rom question
    By wolfhead in forum Introductions
    Last Post: 02-22-2014, 01:19 PM
  3. Question about audio quality on a phone when using a headset
    By Lee Moreau in forum General News & Discussion
    Last Post: 02-21-2014, 07:48 PM
  4. Screen cast question.
    Last Post: 02-21-2014, 03:42 PM
  5. New user questions... Picking one of these up
    By dishe in forum Samsung Galaxy Victory
    Last Post: 02-20-2014, 04:54 PM
