1. ahawkua's Avatar
    Just in case they take an extension i like off the google chrome store, how could i save the extension?
    02-22-2014 04:39 PM
  2. Aquila's Avatar
    Not sure I understand, it'd sync between all browsers you have set up to sync. Do you mean in order to edit it or save it for what purpose?
    02-22-2014 05:04 PM
  3. ahawkua's Avatar
    Just in case they take the extension off the chrome store i'd like to be able to save it to my computer.
    02-22-2014 05:05 PM
  4. Rukbat's Avatar
    I don't use Chrome, but on Firefox there are a few ways of doing that. Isn't there a "backup extensions" function in Chrome? If not, someone wasn't thinking when they designed extensions into Chrome. For example, how do I move my 35 installed extensions to my new computer? Download them one at a time again?
    02-22-2014 07:03 PM
  5. B. Diddy's Avatar
    As long as you're logged into desktop Chrome with your Google account, any other desktop Chrome browser that you open and sign into will automatically sync all bookmarks and load up any extensions. They're all essentially backed up in your Google account.
    02-22-2014 11:08 PM
  1. Can't save (or move) apps to SD card
    By mking2673 in forum Samsung Galaxy Note 3
    Last Post: 02-05-2017, 05:31 AM
  2. Replies: 2
    Last Post: 09-21-2015, 02:39 PM
  3. How To Reset Pic Editor Choice?
    By Alniter in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-23-2014, 01:56 PM
  4. Do you conserve your battery power?
    By droidntn in forum Samsung Galaxy S4
    Last Post: 02-22-2014, 06:39 PM
  5. Replies: 3
    Last Post: 02-22-2014, 04:21 PM
