Results 1 to 3 of 3
    tedsc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How do I get Google Maps offline without voice command?
    I went to cache a map to day for offline use and couldn't find anyway to do so without using the voice command. This is inconvenient for me because I dislike voice commands but it occurs to me that killing the old menu option means people who do not talk CAN'T use offline mode anymore. That seems really backwards to me. I get having voice command as an option but having it replace the standard method altogether seems to limit accessibility. I thought Google was more forward thinking than that.
  2. Best Answer
    Posts
    Global Posts
    23 Global Posts
    Update, I found that you can type "Okay Maps" into the search bar for the same result as the voice command. This is not mentioned in the "Tips and Tricks" section of Google maps however, I found it on a third party site.
  3. Thread Author  Thread Author    #2
    tedsc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Google Maps offline for deaf people?
  4. #3
    srkmagnus's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    That's good to know - Thanks for popping back in and sharing your find.
  1. Google Play Connection Timed Out Retry Error
    By readhpr in forum General News & Discussion
    Last Post: 01-03-2017, 08:22 PM
  2. Default number for Google Now?
    By jerethi in forum General Help and How To
    Last Post: 04-14-2014, 11:11 PM
