Results 1 to 4 of 4
    Default Charging two devices from one plug
    My moto X came with a wall charger than can handle two USB cords and charge simultaneously. Was wondering if anyone knew if charging two things at once is slower than normal. To be specific I'm charging my moto X and Nexus 7. Thanks!
  2. #2
    Default Re: Charging two devices from one plug
    Quote Originally Posted by Sam12Ash View Post
    Hi, I believe it is safe to charge both devices at the same time, but I'm not too sure about the level of power each device would receive. I think the power outage would be slighty less while charging two devices. Best way to find out is to test it
  3. #3
    I charge two devices simultaneously in the same electrical outlet all the time, but each device has its own charger and USB cord.
    Sent from my Nexus 5 using Tapatalk 2
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Whether it's slower depends on the charger. Some chargers can supply rated current from each outlet simultaneously, some can only supply rated output from one output at a time.
    (It's like the old stereo specs used to be stated - something like 100 Watts per channel. But that was measuring with sound on one channel only. Try both channels running and you'd be lucky to get 45 clean Watts per channel.)
    It certainly can't hurt the charger or the phone, though. The phone will draw as much as it can, up to its maximum charge rating. The charger will supply as much as is called for up to its maximum capability. You could probably charge 20 phones on a 1 Amp charger - if you were willing to wait few days.
  1. HTC One or Note 3???
    By WildCatBBN3 in forum AT&T
    Last Post: 07-13-2014, 10:13 PM
  2. 4.42 HTC One..how do I get rid of the lock screen?
    By nneptune in forum Android 4.4 KitKat
    Last Post: 06-09-2014, 08:10 PM
  3. Switch from ATT to Straight Talk -- Good idea??
    By danielinthelionsden in forum HTC One M7
    Last Post: 03-02-2014, 04:38 PM
  4. Switching to android from windowsphone - very low budget
    By dan1232878 in forum General News & Discussion
    Last Post: 02-26-2014, 03:25 AM
  5. HTC One data roaming
    By chance3279 in forum HTC One M7
    Last Post: 02-24-2014, 12:30 AM
