Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 85
Like Tree8Likes
  1. #51
    SoLfrio's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Angry Re: Random apps keep installing by themselves
    mobogenie is more agressive at all UC browser aplication that uses many other people with their smart phone/android or something else... im the one uses that browser because its great for surf and downloads.. but thats the issue about auto installing like mobogenie, DU battery saver, Hola launcer, apus launcer, 360 security etc. and pop-ups...
    ... i think im not the only one suffering this kind of situation from my device..
  2. #52
    APUSAPPS's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Random apps keep installing by themselves
    Quote Originally Posted by SoLfrio View Post
    We're sorry to hear that our app also was a part of this "black" promotion.
    Our developers made a tool to fix this problem and delete this unofficial APUS Launcher with all ads.
    Here is an instruction:
    Instruction
    The tool's apk is attached, and please follow instructions below to perform the uninstallation.
    1. Make sure your phone is rooted, and please also grant root access permission to this tool
    2. Download the apk from this email's attachment and install it
    3. Open up the app (Booster+)
    4. Tap the 3-dots icon on top right corner
    5. Select "Transfer APUS Launcher", then wait up to 30 seconds
    6. A window will pop up, tap reboot.
    7. After rebooting your phone, you should be able to uninstall APUS Launcher.
    Attached 3 screenshots to make the process clearer.
    Please note that you will only be able to see the "Transfer APUS Launcher" option if you have the unofficial version of APUS Launcher (forcefully) installed on your phone.
    We hope this can solve the problem, please let us know if you encounter any issues.
    Thank you. Looking forward to hearing from you soon.
    If you have any questions, you can send us to help [at] apussupport [dot] com
    Attached Thumbnails Attached Thumbnails Random apps keep installing by themselves-02.png   Random apps keep installing by themselves-03.png   Random apps keep installing by themselves-01.png
    Attached Files Attached Files
    reign delfin likes this.
  3. #53
    CheMonk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tom Duritsky View Post
    My phone came with a Monkey test that I can not get rid of, any ideas on how to get rid if it
    No cure man... you must re-flash your device.... i did with mine....
    or you can disable that monkeytest by force, but it will still there and create more when you restart your device
  4. #54
    Shaannnn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i do the same even this time i m using new google i.d and password but its not working as well as i reset my phone but still apps are downloding and installing without knowing me
  5. #55
    Shaannnn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    same but apps are different with me
  6. #56
    Rosemarie Pascua's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    application has auto-installed at my phone, i've already unchecked the box for allowing apps then i also unchecked the 3 dots in google play store for auto-update apps, but all of those is doesn't work.
  7. #57
    Sanjaya Sapkota's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SaqibSoftwares View Post
    A malicious app silently download and install other malicious apps without user permission so you just needs to find that malicious app. Malicious app can also be on Google Play as well as from unknown sources. Because you can't detect which app is malicious you have to follow the following security tips.
    1.Uninstall all the unnecessary apps. (the apps you have some doubt on them)
    you can get the list of all apps here Setting > Apps > Downloaded
    2. Restrict background data/wifi access of all apps except (Facebook, whatsapp, twitter, google play and all common apps)
    because malicious apps use background data/wifi to download other malicious apps/ads and upload your data (logs, passwords, pics etc) to the hacker. So by restricting of background internet usage malicious apps can not download/upload secretly.
    Setting > Data usage > select each app one by one you want restrict > scroll down > check "Restrict Background Data".
    3. Install an advance firefall from google play (check the rating and reviews while selecting one) and create rules which app can access internet.
    A malicious app can be more dangerous than your thinking. It can secretly record your video and can take pictures from your front and back camera without your knowledge it can also record your passwords, can leak your contacts, can read your whatsapp and much more you can't imagine.
    So Please take care all.
    Well, This is really working currently but need to wait how well this work later. Hope this will work later as well. But thanks anyway.
    BEST SOLUTION:::::. 1.Install an advance firefall from google play (check the rating and reviews while selecting one) and create rules which app can access internet.
    OR
    2.I went into "Performance" and "Data Usage", noticed that one of those 5 apps (named- "engrils") has used enormous data in wifi. I immediately went into app manager, cleared all data and disabled this app, along with the other 4, Thats the end of the agony.. Now my phone is superfast even when wifi is connected and no more unnecessary installations..
    Enjoy!!!!!!!!!!
  8. #58
    gold_slug's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Pls help me. I have some trouble in my phone, because it keeps installing apps that i dont want. My phone is rooted by KINGROOT. PLEASE HELP.
  9. #59
    valkiery29's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i already have a solution now. 1st install AVG protection then scan for malware. then if malware was found. install kingroot. then uninstall the found malwares in kingroot.. mines malware was ConfigService and SmsManager that install random app like Apus Launcher , DU Booster, Wifi key masster etc. no need to flash your Android. Cheers from Philippines.
  10. #60
    sravan437's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Me to same problem
    After factory reset also automatically installing some apps like
    UC mini browser
    360 Antivirus
    Du battery
    wifi master key
    apc
    etc.... its going on installing unwanted apps
  11. #61
    Shaikh Asim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    One thing I want to ask u and all, did u install 'IMO'. Your device is infected by IMO, it's a most dangerous virus, there is no solution till yet, it's never gone even after 'flashing'. U have only one solution just change the device, you cannot do anything.
    I suggested you all that don't install 'IMO'.
  12. #62
    drcdouglas's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    a virus called malware is the problem .i know you have tried lot of things ,but you dont get any result.this solution is only those who tried and failed in factory reset /wipe out.download a new rom from XDA DEVELOPER and install() it.if you dont know how to root please see some tutorial videos.there is no other solution than this because malware is already installed in you stock rom .please try it .be careful while rooting.
    try to use cynogenmod rom only if available from trusted supplier
  13. #63
    madmax781's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had a similar problem, In the end it was because I had an infected version of Google Play.
  14. #64
    Nrayan mulik's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool Re: Random apps keep installing by themselves
    hey! u can always go for _ flashing your phone software by u r self or get it done by the service center,
    that's the only way to get rid of such stuff in an andriod system.
    hope u get ur best !!
  15. #65
    mahesh8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey bro i hve one solution for Sony user....u can re install your os officially to avoid this problem.
    The solution given here is already being old ideas so dont give bul**** ideas to member formate,reset and uninstalling app,even child also knew this ******* stuff..
    And by formating this error will not completely removed so dont give wrong direction.
    Thank you i m working on this solution i wil notify soon
  16. #66
    mahesh8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Plz dont share ur rooting mobile idea its an last option and cause damge or can damage your phone if anyone not knowing proper steps.
  17. #67
    Al O's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,
    in my case apps that install themselves is because another (preinstalled) app is installing them.
    So, in order to remove apps that are preinstalled by the manufacturer (or someone else) you have to do the following:
    1.-) root your phone.
    2.-) Install adb and fastboot in your computer.
    3.-) access your phone terminal (like a linux terminal) by using the following command:
    adb shell
    --With this it will appear a new prompt something like "shell@something:/ $"
    there, you must change the user to "root" (like an admin) by typing "su" at the prompt:
    shell@something:/ $ su
    after typing that, the "$" symbol should change to "#" meaning that now you have full privileges over your phone system (be careful).
    Preinstalled apps are located at /system/app/ and also in /system/priv-app
    So if you want to uninstall some of them, you just have to remove them (once again, be careful with that).
    you can list the apps installed with the command "pm list packages -f"
    Hope this can help someone!
  18. #68
    GingerBelle13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: Random apps keep installing by themselves
    I have this same problem and have tried many times to remedy the problem, all to no avail. Mostly the apps are games, such as Likin Hero, Ten Drop etc.. I just uninstall them and then go off line until it's absolutely necessary to reconnect, then repeat the procedure. It's a pain and I have worried about viruses, but so far I've been fortunate. Please let me know if anyone ever figures out how to prevent this, or how to report it when it does. Thanks. By the way, I love your "Crow" profile picture.
  19. #69
    Ravi Sharma13's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its a malware..
    Know the problem first
    This Malware Can Secretly Auto-Install any Android App to Your Phone
    And here is the solution..
    Install a new rom specific for your device
    http://androidmtk.com/flash-stock-ro...one-flash-tool
    Please be careful with the installation
  20. #70
    Hydroliko's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i can help you..
    Just Install "ABP." Add Blocker Download it from playstore.
    It is working on my Samsung Galaxy S6.
    VIRUS BLOCKED
    ADD BLOCKED
    TOTALLY WORKING
  21. #71
    marijay's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem but I fixed by flashing new rom I mean stock rom
    because factory data reset is not enough they are still there if you reset.
    Kingroot is also good if you can root it so that you can uninstall unwanted apps
    I hate it when it attack my phone because they can install and download apps , my phone keeps on restarting when i tried to uninstall something .
  22. #72
    kesavn's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes , mine is rooted . Please explain how to get rid of these spamming apps.
  23. #73
    hamzara's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    hi every1,
    i am facing same problem.my builtin apps or file show ads.and its aritates me.the file name that show ads are
    1-Smsmessager
    2-Settingprovider
    3-Certificate
    and apps also automatically downloaded....
    please help me.
  24. #74
    belodion's Avatar
    Posts
    Global Posts
    19,790 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Random apps keep installing by themselves
    Quote Originally Posted by hamzara View Post
    hi every1,
    1-Smsmessager
    2-Settingprovider
    3-Certificate
    please help me.
    Welcome.
    If none of the suggestions in this thread is of any help to you, I don't know that we have anything else to offer.
  25. #75
    Rahul2000's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    in my phone when data is switched on or connected to wifi ...some unwanted apps get installed by themselves (including some porn apps)...i hate this and also it consumes my phone storage....now what should i do ..i installed STUBBORN TROJAN KILLER but it says no malware found!...Plz anyone can help me out with this problem?
  1. [GAME] [APP] Underwater Crisis Version 1.1 [FREE]
    By altairirfan in forum Android Games
    Last Post: 04-08-2015, 09:46 PM
  2. New mid level device by HTC
    By Golfdriver97 in forum HTC Desire 816
    Last Post: 03-04-2014, 02:03 AM
  3. Replies: 1
    Last Post: 02-24-2014, 05:16 PM
