1. Thommo1977's Avatar
    Hi i was running jelly bean 4.3. I rooted the phone & performed a full nandroid backup to external sim card.
    I upgraded to Kitkat 4.4. But i dont a=have any mobile signal.
    I am with telstra in Australia.
    How can i fix this?
    Also how do you update su binary code?
    Can i downgrade back to jelly bean?
    Thanks for your help
    02-24-2014 05:49 PM
  2. Golfdriver97's Avatar
    Welcome to the forums.
    You can restore your backup, and it will return your device to the way it was.
    UJ95x likes this.
    02-24-2014 11:05 PM
  1. Galaxy S5 has the storage problem the Galaxy S4 had
    By smooth4lyfe in forum Samsung Galaxy S5
    Last Post: 03-08-2014, 03:54 PM
  2. Major problems with Nexus 10 RMA
    By Scamper Gear in forum Google Nexus 10 Tablet
    Last Post: 02-25-2014, 09:53 AM
  3. Problem when modifying vold.fstab - no sd card found
    By celmassry in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-24-2014, 11:54 PM
  4. Problems with frame rate and taps
    By shalmu in forum General Help and How To
    Last Post: 02-24-2014, 11:58 AM
