Results 1 to 8 of 8
Like Tree3Likes
  • 2 Post By sfrrr
  • 1 Post By srkmagnus
    Default Won't update - - says my international S3 has been modified
    What does that mean? The S3 (running 4.3) is not rooted, not flashed, not damaged. So, what does MODIFIED mean here?
    I may have disabled a file i shouldn't have. (I have disabled a bunch of apps in the Manage Apps setting.)
    I've been re - enabling apps one by one, but it's tedious.
    Any ideas about what app could have caused the message? Or about what else might be the problem?
    Thanks.
    GT-I9500 running 4.3
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default Re: Won't update - - says my international S3 has been modified
    It's likely the disabling of the apps. If that doesn't work, the only way to fix it is by flashing stock firmware onto the phone. That will delete all of your data so make sure to back it up
    Sent from my Galaxy S4 running SlimKat 4.4.2
    You 'd think that flashing firmware would be considered modifying. Don't i need to be rooted in order to flash stiff on my S3?
  4. #4
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Backup your data and factory reset. Try to install the update afterwards and see if that works. All your apps should be restored and there should be no issues with updating if you are completely stock, not rooted.
  5. #5
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Quote Originally Posted by sfrrr View Post
    Sorry for the late reply. Flashing stock firmware can be done through Odin, in which case you don't need to be rooted, and no it's not considered modifying.
    Thanks muchly to both of you. Tomorrow i do a full backup and then do a factory reset. If that doesn't work, I'll move onto Odin. I'm actually looking forward to all this mess because the S3 is full of file fragments and other junk. Thanks again.
    srkmagnus and UJ95x like this.
  7. #7
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Let us know how it goes.
    UJ95x likes this.
  8. Thread Author  Thread Author    #8
    I found the cause. That phone doesn't have a sim card. Thanks, you guys, for all the help.
    GT-I9500 running 4.4.2.
  1. Replies: 8
    Last Post: 05-19-2015, 08:00 AM
  2. Galaxy S3 owners is the S5 a good enough upgrade for you needs?
    By HOLLYWOODANT215 in forum Samsung Galaxy S5
    Last Post: 02-26-2014, 07:26 PM
  3. Where did my contact pictures go
    By theresamichelle in forum Sprint Samsung Galaxy S4
    Last Post: 02-26-2014, 01:48 PM
  4. Made Sochi Manhole and saying Hi
    By Christopher_pixelStorm in forum Introductions
    Last Post: 02-25-2014, 06:10 PM
  5. S3 i9305 Problem
    By Thommo1977 in forum General Help and How To
    Last Post: 02-25-2014, 12:05 AM
