1. reinbeau's Avatar
    I have the Captivate. I looked all over, and I can't see where I insert an SD card. Please be kind - I am in totally uncharted waters here. I see a card inside, do you replace that one? Thank you for your gentle help
    09-23-2010 09:25 PM
  2. takeshi's Avatar
    Samsung's site has a manual that you can download and refer to if no other Capitvate owners chime in. The slot looks like it's right next to the SIM slot and the battery from what I can tell.
    reinbeau likes this.
    09-24-2010 09:48 AM
  3. reinbeau's Avatar
    Thank you - I will get the manual
    09-24-2010 07:05 PM
  4. Kyle Gibb's Avatar
    Look at our review for the phone. Scroll down a bit until you see the picture with the back off the Captivate. Click on it to see the full rez version. The Micro SD is right to the left of the SIM.
    09-27-2010 09:25 AM
