Samsung Note 8 AT&T - Trouble Rooting
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Try Kingo. The worst that can happen (other than growing old waiting for the download - the server is sometimes very slow) is that it'll tell you that it can't root your device. As far as instructions, connect the tab to the computer, install Kingo and run iit. When it connects to the tab, click the "Root" button. Sit back and watch grass grow (it takes a few minutes, downloading the right files for your device, and it will probably reboot at least once). When the Root button turns into a Finish button, click it.
Save Kingo, because if you run it on the tab again, Kingo becomes an unrooting program (in case you should ever want to unroot).
MarcosVo
