1. Sicco Blue's Avatar
    hey my samsung galaxy s3, the screen has turned purple. the power button, volume, and home button are working fine. so is he led light. but whenever i turn it on the screen turns purple. the bottom two buttons (arrow and the thingy) they both light up and work fine. today i turned off my phone, left in my locker then went to class. then i came back turned it on, it was all glitchy with purple strips. it was turning on and off. then i could still see my lock screen. but now its al purpleHelp!!! URGENT!!!-download.jpg its like this color and i can't see or do anything else. when i swipe in the password, it lets me go in, cause when i did that i was dialing a phone number, and i was taking pics cause i knew where the camera button was. so please help!!
    02-26-2014 07:41 PM
  2. Aquila's Avatar
    If there are no visible cracks/blemishes on the glass the most likely this is a faulty or poorly connected digitizer. How long have you had the device, is it still under warranty?
    Eclipse2K likes this.
    02-26-2014 08:02 PM
  3. srkmagnus's Avatar
    Also, was there anything you did before the screen changed to purple? We're you trying to edit system files and or the dpi?
    If not, seems like a repair or replacement is needed. Contact Samsung to see what you need to do for repair.
    02-26-2014 09:47 PM
  1. I need your help, photos on sd card gone
    By THEPRFCT10 in forum Samsung Galaxy S4
    Last Post: 10-24-2015, 10:07 PM
  2. HELP !! bricked HTC One
    By shanewilliamson in forum HTC One Rooting, ROMs & Hacks
    Last Post: 03-03-2014, 10:29 PM
  3. Help erasing signs of rooted phone
    By Hebaz in forum Verizon LG G2
    Last Post: 02-28-2014, 07:48 PM
  4. Replies: 1
    Last Post: 02-26-2014, 10:26 PM
  5. Need help with wife's phone
    By arkieman in forum General Help and How To
    Last Post: 02-26-2014, 05:59 PM
