1. paulablowers's Avatar
    rite iv got an s3 mini its not goin past the charging screen and wen it did the samsung logo befor it comes on is red behind it and not blue
    02-27-2014 04:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I don't quite understand--you're saying it doesn't go past the charging screen when you try to power it on, while connected to the charger?
    How old is the phone? The battery might be having problems--take it out, place it on a table, and try to spin it. If it spins freely, it's bulging in the middle and therefore is going bad and should be replaced.
    02-27-2014 04:46 PM
  3. paulablowers's Avatar
    hi no battery is fine and yeh i turn the fone on the samsung logo flashes red behind it then the screen stays on samsung galaxy s3 mini and wont got no further
    02-27-2014 04:51 PM
  4. B. Diddy's Avatar
    Try booting into Recovery, and wiping the system cache partition, as described in this link: [Guide] Rebooting into Recovery Mode for the Galaxy S2, S3, and Tab2.. You won't lose any personal data or settings.
    02-27-2014 04:52 PM
  5. paulablowers's Avatar
    hi i do that and it just stays on the samsung logo i get no info to boot or recover
    02-27-2014 04:57 PM
  6. paulablowers's Avatar
    This s3 mini came on lastnite to the set language screen wudnt go any further and now wont *** on at all and its not the battery thanks
    02-28-2014 02:02 PM
  1. Moto G wont uninstall apps.
    By Sobha Gadi in forum Android 4.4 KitKat
    Last Post: 05-18-2014, 01:23 AM
  2. Weird wifi issue, not loading any apps with images?
    By Deaglegame in forum Google Nexus 5
    Last Post: 04-04-2014, 10:13 PM
  3. 4G takes forever to load contacts
    By Sandra Arnold in forum Verizon Droid Incredible 4G
    Last Post: 03-07-2014, 05:44 PM
  4. Replies: 0
    Last Post: 02-25-2014, 10:17 AM
  5. Please help... Play Store HOME PAGE will not load
    By Arielle Williams in forum Samsung Galaxy S4 Mini
    Last Post: 02-22-2014, 02:47 PM
