Results 1 to 3 of 3
Like Tree1Likes
  • 2 Post By B. Diddy
    skstrials's Avatar
    Posts
    Global Posts
    2,363 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Does having "recently opened apps" open shorten the battery life?
    Hello, I started using a Galaxy S3 a couple weeks ago.
    I am mostly getting used to it, but I noticed that when I close an app, the app goes to the task manager and I have to manually close it from there fully.
    So what I want to know is
    1. Is it necessary to close the apps from the task manager?
    2. Up to how many apps can the task manager carry before it starts automatically closing apps?
    Thanks!
  2. #2
    B. Diddy's Avatar
    Posts
    Global Posts
    77,882 Global Posts
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Does having "recently opened apps" open shorten the battery life?
    Welcome to Android Central! Don't worry about closing apps yourself--that's not how Android is designed. You should only try to close apps yourself if something seems to be malfunctioning. Read this article for more information: http://www.androidcentral.com/ram-wh...-shouldnt-care
    Rick Bell and skstrials like this.
  3. #3
    someguy01234's Avatar
    Posts
    Global Posts
    1,820 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by skstrials View Post
    Thanks!
    I'm not exactly sure how it is for normal android, but a few custom roms have ways to tweak how the phone behavior at varying ram level, most new roms are so well optimized so they don't even have this feature. In "Developer options" menu in Settings, there is an option called "background process limit", but it doesn't save after each reboot.
    One thing that's true is if you clear the apps from 'recent apps' menu, it will actually release some ram. So I would do it before loading a big game.
    But overall, if your phone have 2gb of ram or more, you shouldn't really be concerned about clearing apps often.
    One way your battery may be affected is due to "wakelock", you can use an app like Greenify to hibernate apps so they don't run in the background and use battery.
  1. I have KitKat on T-Mobile
    By jmarkey77 in forum LG G2
    Last Post: 03-02-2014, 07:17 PM
  2. So apparently the Sprint S4 got the ART Runtime, but AT&T didnt?
    By sniffs in forum AT&T Samsung Galaxy S4
    Last Post: 03-01-2014, 11:05 AM
  3. Alternative camera app
    By Skinnyman9000 in forum Google Nexus 5
    Last Post: 02-28-2014, 06:10 PM
  4. Replies: 0
    Last Post: 02-28-2014, 12:59 PM
  5. Google Reader app using tons of data?
    By kasxperanto in forum General News & Discussion
    Last Post: 02-28-2014, 12:36 PM
