Results 1 to 2 of 2
    Talking Samsung Epic can't locate GPS.
    phone can't find gps, no idea why.. im really really annoyed and upset and don't like computers...
    nothing worked --
    INTELLIGENT COMPUTING: Google Map: Can’t find my Location even if GPS is ON [Solved]
    GPS PROBLEM NO SATELLITE what so ever | Galaxy Nexus > XDA
    Phone Model: SPH-D710 (samsung epic)
    Android Version: 4.1.2
    Baseband Version: S710.10 S.GB27
    Does anyone know how to troubleshoot?
    more *** ~ List Of All The Best Android Apps For Each Type/Function, Please ~ ***
    *** ~ Can't Locate GPS ~ ***
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,810 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: Samsung Epic can't locate GPS.
    Install GPS Status. It'll show you which satellites the receiver sees, and which ones it's locked into.
    If it doesn't see any, it's possible that your GPS antenna isn't connected. (Fixing it is trivial, paying for the labor to do it isn't.)
  1. Samsung Galaxy S3 not recognizing SD Card
    By Becka Knaak in forum Samsung Galaxy S3
    Last Post: 11-19-2016, 11:11 AM
  2. Samsung releases KitKat source code for Tmo Galaxy Note 3
    By Deke218 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-05-2014, 11:25 AM
  3. Can I disable this from showing?
    By Kathie Adam in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-02-2014, 06:01 PM
  4. Samsung Galaxy S3 Cannot Communicate
    By brian1childs in forum Google Chromecast
    Last Post: 03-01-2014, 11:57 PM
