Results 1 to 4 of 4
    deeve's Avatar
    Posts
    Global Posts
    32 Global Posts
    Default Current Status of Syncing iCloud with Android
    Hello, I'm about ready to make the jump from iOS to Android. I am pretty deeply imbedded with Apple by having an iPad, macbook and family using apple. We use the iCloud calendar quite a bit so it would be a requirement that I continue to use it. What is the current situation with syncing and using a 4.4 os with iOS 7? I have read some stuff, but it was older. Has anything changed? Is it still something that can be done with relative ease? Those who are using it... Any caviets you noticed or wish you had done differently?
    Thanks,
    Dave
  2. #2
    Aquila's Avatar
    Gonfaloniere
    Posts
    Global Posts
    13,555 Global Posts
    Carrier
    Assassin 'Droid
    Default Re: Current Status of Syncing iCloud with Android
    Unfortunately it mostly depends on which device you're switching to. There are generic tools to facilitate, but some such as Motorola's, are better than others.
    deeve's Avatar
    Posts
    Global Posts
    32 Global Posts
    Quote Originally Posted by NothingIsTrue View Post
    That might be good news for me. I will be getting a Moto X DE
  4. #4
    I think the sync wont work out of the box (at least on my device) and this requires to install/utilize additional apps. Then it works fine (but I only can speak for my iCloud account on my device). I used two additional apps to sync my iCloud calendars and iCloud contacts. Configuration was quite straight forward. So first I tried to sync my contacts and used this here ContactSync and later on I also wanted to get my appointments and installed this here CalendarSync Both mention iCloud at their description so I simply asked the developer how to sync with iCloud and he sent me this tutorial (I used it and got a working sync so I can recommend it):
    The configuration for iCloud is really simple. Please use the guided configuration mode to create a WebiCal/WebContact.
    For CalendarSync.
    Start App -> Press Menu button -> Select create WebiCal -> Select guided configuration mode (top most button) -> fill in:
    URL:https://caldav.icloud.com/
    Username+Password:You Apple Id and the matching password
    Press Test Connection -> Press Search calender -> Select which calendars you want to sync and Press Configure calendars -> Press the back button until you are back at the main screen and Press the top most Handle WebiCals button to start your first manual sync (of course you can also configure the app to sync automatically)
    For ContactSync.
    This is quite similar to CalendarSync, but you will need to create a WebContact (instead of a WebiCal) and use a different url ->https://contacts.icloud.com/
  1. Am I the only one to get rid of as many tiles as possible?
    By MikeSp in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 03-07-2014, 05:43 PM
  2. Sell Note 2 now with 4.3 or worth more if 4.4 in a month(ish)
    By Matt Behnken in forum AT&T Galaxy Note 2
    Last Post: 03-02-2014, 12:57 PM
  3. Amazon Android Apps Won't Open (But They're There)
    By Alniter in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-28-2014, 09:04 PM
  4. Sync your harddrives more often.
    By someguy01234 in forum The Android Central Lounge
    Last Post: 02-28-2014, 05:04 PM
