1. Nexus 10 User's Avatar
    Newbie here
    It appears that I have deleted or moved the popular app folder from the Android Dock or favorite bar. Can some tell me how i can get it back?
    Thanks
    03-02-2014 03:02 PM
  2. B. Diddy's Avatar
    Welcome to Android Central? What do you mean by the popular app folder? Was it an actual folder of apps? If it got removed from the homescreen, then you'll have to create it again yourself. Folders are customized, and not saved anywhere.
    03-02-2014 05:12 PM
  3. Nexus 10 User's Avatar
    Thanks for the reply!
    I was icon that was in the android Dock/favorite bar at the bottom screen Help: popular app folder missing the Android Dock-capture.jpg I have attached a small screen shot from the manual referencing the icon in question. Does this help any?
    Thanks again
    03-02-2014 05:36 PM
  4. B. Diddy's Avatar
    Yeah, that's a folder that probably came pre-arranged for you. If you removed it, you'll just have to create a new folder yourself, which is easy enough. Just open your App Drawer, then start dragging app shortcuts of your choice to the Favorites Tray. After you place the first one, place the second one on top of it, which will create a folder. You can continue placing more app shortcuts into the folder until you hit the limit (which I think depends on screen size). You can label your folder as well by opening it and tapping on the folder title along the bottom.
    03-02-2014 06:24 PM
  5. Nexus 10 User's Avatar
    Thanks B.Diddy I got it now!
    B. Diddy likes this.
    03-02-2014 06:59 PM
  1. file transfer between android and chromebook
    By Dryophila in forum Chromebooks
    Last Post: 10-05-2016, 12:45 PM
  2. Replies: 5
    Last Post: 07-20-2015, 05:20 PM
  3. Screen cracked, cant unlock to access pictures...HELP!
    By littleannieoakley in forum Verizon LG G2
    Last Post: 08-20-2014, 03:07 PM
  4. AT&T Galaxy S4 (I337): hung on boot logo. Help
    By Kenny Turner in forum AT&T Samsung Galaxy S4
    Last Post: 03-07-2014, 12:01 PM
  5. FM Radios on Androids
    By nirajvashi in forum Software Development and Hacking
    Last Post: 03-02-2014, 02:15 PM
