Results 1 to 5 of 5
    JohnBlaize1974's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy Note 3 Wont screen mirror
    Hi. I recently swopped my experia Z1 for a galaxy Note 3 but when i go into connections and select screen mirroring it just says empty instead of trying to search for devices. It does this for s beam and Kies etc also. I have a feeling some sort of driver may be missing. Can anyone help as this is very frustrating?
    I am running android 4.4
    Thanks
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    Default Re: Galaxy Note 3 Wont screen mirror
    Screen mirroring is to a compatible Samsung TV set. If you don't have one running nearby you'll see a blank area where the devices would show up.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi. No thats incorrect. My TV is a new Sony smart TV and my friend has a Samsung Galaxy S3 and his connects straight away. Even if we are outside with no TV's around his phone will still search for something. Mine just says empty regardless of whether there is a TV around or not.
  4. #4
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    I don't know about the S3 (I don't have one) but the Note 3 will only mirror to a Samsung SmartTV. (I wish it would work with other TVs - then I could use my Vizio as a larger monitor. I did the research - it won't.) You should see "scanning" for about 10 seconds, then "no devices found".
  5. #5
    Ealevenish's Avatar
    Banned
    Posts
    Global Posts
    154 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you install Teamviewer Quicksupport (free) on your SGN3, and Teamviewer (also free) on your laptop or desktop computer, and fire both of them up, your SGN3's screen is mirrored on your laptop or desktop computer's screen. Not only that, but you can operate your SGN3 from that laptop or desktop computer. With a big screen and a full size keyboard! Very convenient! Also for SMS-ing or instant messaging!
    If you have a 'smart TV' on Android, with a web connection, I expect this to also work on that TV if you install Teamviewer on it.
  1. How do you backup screenshots on android? (samsung galaxy s4)
    By rebel2401 in forum General Help and How To
    Last Post: 12-30-2015, 09:21 AM
  2. My samsung galaxy tab 2 wont charge when it is turned on
    By asharam in forum Samsung Galaxy Tab 2
    Last Post: 06-11-2015, 02:00 PM
  3. N7000 wont go into recovery mode(and stuck in logo loop)
    By Aidan Wood in forum Samsung Galaxy Note
    Last Post: 10-02-2014, 04:01 AM
  4. Sony Xperia SmartTags use with Note 3?
    By TXGTOU in forum Samsung Galaxy Note 3
    Last Post: 03-04-2014, 01:41 AM
  5. Lock screen app with pattern security
    By MissPrettyKitty in forum Android Apps
    Last Post: 03-03-2014, 05:15 AM
