Results 1 to 6 of 6
    tenf00t's Avatar
    Posts
    Global Posts
    9 Global Posts
    Default Nexus 5 rings even when set to vibrate/silent
    Hey guys, weird problem here. I have a rooted Nexus 5 with KK 4.4.2 that rings even if set to vibrate. The phone vibrates once and then the rigner actually is set back to full volume. Pretty annoying during meetings.
    Any ideas?
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Nexus 5 rings even when set to vibrate/silent
    Quote Originally Posted by tenf00t View Post
    Any ideas?
    Open Settings - Sounds. Check to make sure all the sounds are turned down. If you press the volume rocker all the way to silent and see the icon display silent then there should be no sound. If you still have sound something else could be interfering with the setting. Take a look at what's installed and consider a factory reset of the problem persist. It shouldn't be root related. At least not rooted itself.
    tenf00t's Avatar
    Posts
    Global Posts
    9 Global Posts
    Quote Originally Posted by srkmagnus View Post
    It's really weird, If i press the volume rocker all the way down it does show the silent icon but as soon as I receive a call it goes all the way back up again. I assume a factory reset will solve my problem but was hoping to avoid that
    tenf00t's Avatar
    Posts
    Global Posts
    9 Global Posts
    Ok, figured it out. I had the app Sound Profile installed which turns sound off at night and turns them back on in the morning. I had already tried disabling the app to see if it was the culprit but apparently it had to be uninstalled. I'll try to figure out if I can configure it some other way. Thank you
  5. #5
    srkmagnus's Avatar
    Posts
    Global Posts
    13,715 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    No problem - Glad you were able to find the culprit
  6. #6
    Thanks for the tip... This was driving me crazy. I had "Profile Scheduler" installed and disabled, once I uninstalled it everything seems to be working again.
  1. Note 3 automatically changes ringtone back to default--help!!
    By ShelbyWright in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-12-2014, 09:46 PM
  2. Moto X: Go to dialer screen?
    By pappy53 in forum Moto X (2013)
    Last Post: 03-06-2014, 12:55 AM
  3. Replies: 0
    Last Post: 03-03-2014, 11:11 AM
  4. when you download sothing from a text message where does it go
    By merlin7777777 in forum Samsung Galaxy S4
    Last Post: 03-03-2014, 10:08 AM
  5. Replies: 0
    Last Post: 03-03-2014, 08:38 AM
