1. wolfhead's Avatar
    Purchasing a jabra Bluetooth for work purposes and was wondering if its possible to answer my texts through Bluetooth. Since I have voice to text could sending by Bluetooth be possible?
    Thanks for any help !
    03-03-2014 12:20 PM
  2. FutureKix's Avatar
    Hmm. All I can think of is the "Assistant" app by Speek to it. Among other features, it allows you to send and receive SMS, and separately it has a beta mode to interact with it via a connected Bluetooth headset. It works with my Turtlebeach XP400s. It announces new messages, allows me to reply, and I can send a message at any time by saying "Send message" + "Hi (or whatever)" + "Barbara" + "Yes".
    03-03-2014 12:40 PM
  3. wolfhead's Avatar
    Thanks for reply !
    03-03-2014 12:53 PM
  4. FutureKix's Avatar
    Thanks for reply !
    Hope this helps you! If you choose the Assistant and need help I'm your man.
    03-03-2014 02:27 PM
  5. wolfhead's Avatar
    Assistant app on play store ? I seen similar apps. But I'll check out your recommendation. If on play store. Otherwise let me know where else to find it. Again thanks !
    03-03-2014 05:39 PM
  6. FutureKix's Avatar
    Yes, it is in the Play Store.
    https://play.google.com/store/apps/d...toit.assistant
    03-05-2014 02:52 PM
  7. wolfhead's Avatar
    Is that it ? It doesn't mention nothing about Bluetooth. Am I missing something ? Please need your help ! Thanks !
    Sent from my C5170 using Tapatalk
    03-05-2014 09:25 PM
  8. FutureKix's Avatar
    Yes, that is it. Once it's installed, under settings, choose activation, then bluetooth headset (beta)
    03-05-2014 10:43 PM
  1. Replies: 1
    Last Post: 03-13-2014, 12:15 AM
  2. Sprint Galaxy S3: Challenging question (please help)
    By coop616 in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 03-08-2014, 03:31 PM
  3. Typing question
    By marios1441 in forum General Help and How To
    Last Post: 03-03-2014, 04:13 PM
  4. Simpleton questions
    By Ludditejones in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 03-02-2014, 11:28 PM
  5. Moto X: Bluetooth Not Turning on Without Reboot
    By sunads in forum Moto X (2013)
    Last Post: 03-02-2014, 12:07 PM
