Results 1 to 9 of 9
    gil_happy's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How To Send TuneIn Radio On Android Device To A/V Receiver?
    Hello,
    After searching and reading forums, I'm trying to figure out how to stream / send the audio from TuneIn Radio on my Android phone (Samsung Note 3 on T-Mobile) over WiFi in my home to my Yamaha A/V receiver (HTR-4065) that supports DLNA and AirPlay.
    Has anyone figured out a solution to this, i.e. sending audio from a running application, in this case, TuneIn Radio via either DLNA or AirPlay? The reason I'm trying to do this is that the built Internet Radio (using vTuner) on the Yamaha receiver does not have some of my favorite radio stations available, but TuneIn does.
    Thanks in advance!
  2. #2
    sai222's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How To Send TuneIn Radio On Android Device To A/V Receiver?
    Hi gil_happy
    I am just starting a company for streaming solutions, so I am testing a lot of different ways to stream all kind of media to either a DLNA/UPnP- or an AirPlay-receiver.
    I love TuneIn, but unfortunately only the iOS version features streaming over AirPlay. I am in touch with TuneIn Development Team and they plan to add this feature to the Android app too, but we have to wait for that.
    Now the good and the bad news. I found a work nice work-around, I found the app called Skifta. It supports TuneIn log-in and is able to stream to DLNA and AirPlay-receiver. BUT unfortunately they kicked the TuneIn channel out of Skifta, because a lot of users complained about not seeing all their favorite radio stations, but it's not Skifta's fault. It's related to copyrights and distribution agreements. I am searching for a new solutions.
    Greetings
    Mike
    gil_happy's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi, I rooted my Note 3 (I was very nervous about that, but it worked great) and now I can send TuneIn (via AirPlay) to my A/V receiver using AirAudio. It works great!
  4. #4
    sai222's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi gil_happy
    Yes, rooting your phone is an option. I am happy, it works for you.
    I hope to find an "easier" way, because common android users do not root their phones.
    Greetings
    Mike
  5. #5
    Tonny Rabjerg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi,, anyone who have solved this, have spent 2-3 weeks trying to find a solution, but so far I think I have no luck, downloaded just about all DLNA and Radio apps but no luck
    Speaking to my B&O they recommended me to buy an iPhone, which I don't think is the right solution
    please heeeeelp
  6. #6
    Dan Brown10's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am looking for a DMC app whitch supports INET radio for a longer time. The best app I found is DLNA Total. It uses Shoutcast radio station lists. I would prefer an app which supports tunein, surfmusik, vtuner or wifi radio frontier radio station lists but didn't find it. I ask the author of DLNA Total if tunein or surfmusik can be supported but didn't get an answer.
  7. #7
    rut77's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi Folks,
    Getting your tunein stream to your receiver through airplay or dlna is very easy. 1. Root your android ... 2. Download "allstream" app from googleplay and enjoy. You can even use many android equalizers applications (especially I recomanding "poweramp" player) Lets God bless guys who created "allstream". Amen !
  8. #8
    mawil1013's Avatar
    Posts
    Global Posts
    2,526 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, there are blue tooth receivers that plugs into any audio input via micro jack. I have one thru Amazon and have seen them at Loves truck stops. Mine is called miccus mini jack Rx. I know u said WiFi but there is this option also. I plug into car radio input jack. Its recharge able.
  9. #9
    yarrr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For Android - Allstream is the best, but I was able to program TuneIn directly to my Onkyo C-N7050 receiver:
    1. Get the address of the stream like this:
    2. Enter the address on my local device config website (in my local network)!
  1. What is com.sec.android.app.sbrowser? Battery life on KitKat
    By MichaelGrahamLS in forum AT&T Samsung Galaxy S4
    Last Post: 12-22-2014, 08:06 AM
  2. Xperia Z1 Compact: Protective cases on the androidcentralshop?
    By Anders Carlstein in forum Sony Xperia Z1 Compact
    Last Post: 03-11-2014, 05:02 PM
  3. Need to get files off a phone with a broken screen
    By V3N0M_90 in forum Sprint Galaxy S3
    Last Post: 03-04-2014, 05:38 PM
