1. Cody_h4x's Avatar
    Hello everyone!,
    Firstly I had the galaxy gio on a talk and text plan. I went to Virgin mobile and Upgraded to a Galaxy Ace 2 with the silver plan which gets me Picture messaging. So i took my sim card from my gio and put it in my ace 2 and the phones great! Although i cant send or download MMS. My mobile data is turned ON. and it's using the stock MMS APN called Browser (It uses the bell apn). If I try to send a picture than all that happens is it stays sending and says
    "currently unable to send your message.it will be sent when the service becomes available" But never sends, than if I recieve a mms and select download it says downloading but never does. i tried a factory reset, new apns, and sending mms to myself but nothings working!
    Any help is greatly appreciated!
    03-05-2014 02:59 PM
  2. Rukbat's Avatar
    Is there a Virgin or Bell store nearby? Can you go into one of them and ask them to please set your APN so that MMS works?
    03-05-2014 07:51 PM
  3. Cody_h4x's Avatar
    Well my mom has the exact same phone and same plan, she can send picture messages, and i cant. her apn settings is the same as mine and both are phones mobile data is on. The only differences that I think will solve it is that her sim card says virgin Moible LTE on it, and mines an older virgin mobile sim card thats white.
    03-09-2014 03:21 PM
  4. Cody_h4x's Avatar
    Quote!
    03-10-2014 01:32 AM
  1. after update do a factory reset that take care of any problems
    By zaydabarber in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-19-2014, 05:27 PM
  2. Setting wallpaper for Samsung Galaxy Trend Plus?
    By Aesthete18 in forum General Help and How To
    Last Post: 03-07-2014, 10:02 PM
  3. Dash Clock Problem
    By Jwilock in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 03-06-2014, 06:51 PM
  4. Replies: 3
    Last Post: 03-06-2014, 06:55 AM
  5. Galaxy Note 3 - Missing sorting options in Contacts/Settings menu
    By guigs62 in forum Samsung Galaxy Note 3
    Last Post: 03-05-2014, 11:06 PM
