1. cardinalthe's Avatar
    hi my alarm does not go off in my nexus 5 phone when it is switched off
    03-06-2014 03:59 AM
  2. cheeta186's Avatar
    The alarm on the phone will not go off if the phone is off, it needs to on in order for that to happen, as far as I know there is no way to have the phone turn on for the alarm. Unless someone has another suggestion simply leave the phone on overnight.
    03-06-2014 12:48 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! A few questions:
    1. Are you using the alarm from the stock Clock, or are you talking about Reminder alarms from Calendar?
    2. In the Clock app, tap the Menu button, then Settings, then Alarm volume. Make sure it isn't all the way down.
    3. In the Clock app, under the Alarm Clock section, tap on the alarm that you set up, then check which ringtone is listed--make sure it doesn't say "Silent."
    4. When you say the alarm doesn't go off when the Nexus 5 is switched off, do you mean that it's only asleep, or is it fully powered down?
    03-06-2014 01:12 PM
  1. Nexus 7 water damage helpp!!!
    By Eloise Q in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-01-2015, 06:49 PM
  2. Best Apps for Nexus 5?
    By Jimmy Grzybek in forum Google Nexus 5
    Last Post: 04-28-2014, 04:33 AM
  3. Silly Nexus Question
    By flybub in forum General News & Discussion
    Last Post: 03-07-2014, 04:03 PM
  4. Nexus 5: Nillkin screen protectors
    By Paskell in forum Nexus 5 Accessories
    Last Post: 03-05-2014, 11:38 PM
  5. Replies: 3
    Last Post: 03-05-2014, 09:30 AM
