1. Shahbaz Talpur's Avatar
    Hi,
    There's a software for windows "SP Tools" that can install new ROMs and recoveries. I first time used it to flash ROM on my phone Micromax A110. Everything went fine but it changed some memory allocation. My 1.4 GB internal memory was turned into 400+ MB and the space removed from internal memory is added to internal SD card (as well as formatted internal SD card ). How can I revert back?
    03-06-2014 04:14 AM
  2. Rukbat's Avatar
    "Internal SD card" is something new in later versions of Android. You "revert back" by finding a stock ROM for your phone and installing it.
    03-06-2014 02:26 PM
  1. Note 3 not syncing with Google after KitKat
    By Bruno Vun in forum Samsung Galaxy Note 3
    Last Post: 05-20-2014, 07:49 PM
  2. T-Mobile Note 3: Is it me or....did update noticeably improve reception and data speeds?
    By Frozen Corpse in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 03-22-2014, 07:35 PM
  3. I really need these Apps in Samsung Note 3, Please help?
    By kitharass in forum Samsung Galaxy Note 3
    Last Post: 03-06-2014, 07:50 PM
  4. help!!!!!!!! cant set up my gmail
    By xtervaganza in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-06-2014, 04:52 PM
  5. Help!! Mail delivery subsystem messages
    By Bnjf in forum General Help and How To
    Last Post: 03-06-2014, 03:14 PM
