Results 1 to 4 of 4
    Default
    i have my samsung SCH-R740C,and i put the SD card from my previous phone in it. ( it wasnt a samsung.i forgot what it was), and for a while, it was working fine in the new phone. however every once in a while, pictures,videos and music get corrupted and i dont know why.( i would save it to cloud,but it takes an extremely long time even with wifi. google+ backs up alot of ny files for me,but idk if it backs up audio.)
    somehow the phone messes up my files. at first, music that i had already saved on the external SD card i could listen to(although some songs were corrupted and skipped a lot),but any new music had to be in the phone, or else i couldnt play it. now,NONE of the music can be on the exteral card so i have to move it to the phone just to hear it. id rather keep my music on my external SD card,so i could move it whenever i get a new phone,but im afraid that it will forever corrupt the music. any way to fix this?
  2. #2
    Rukbat's Avatar
    Posts
    Global Posts
    22,798 Global Posts
    Carrier
    Modified Stock 4.4.2
    Default Re: my phone wont read SD card music
    Need to know something first - what brand of card is it? If it's an older SanDisk card, it may be subject to the "Samsung corruption". Even though it's Samsung's fault, SanDisk has worked out a patch to the card that fixes the problem, and they'll replace your card.
    If not, install SD Insight (free at the Play store) and run it on the card. It'll give you some idea of what you're dealing with. You can also run A1 SD Bench (akso free at Play) to get a better idea. It could be a counterfeit card or it could just be a card made of reject chips. (I don't work for SanDisk and never have, but their cards are the only ones I'll buy. If they're not counterfeit, I know I'm buying a good card. And a company that stands behind its product.)
    yes, its a SanDisk card. ill try what you suggested,and see if i can fix it. thanks!
    ♥~*Phone Magix*~♥
    Quote Originally Posted by Rukbat View Post
    ♥~*Phone Magix*~♥
  1. Replies: 14
    Last Post: 04-29-2015, 12:10 PM
  2. Skype is down locks up my tablet
    By 1Ando in forum General Help and How To
    Last Post: 12-20-2014, 01:34 AM
  3. Replies: 1
    Last Post: 03-23-2014, 10:11 PM
  4. What phone device is on its way that will be superior to the Galaxy Note 3?
    By yourphonemyphone in forum Rumored Devices Lounge
    Last Post: 03-15-2014, 12:12 PM
  5. Stock music App issue
    By Ninja1990 in forum Verizon LG G2
    Last Post: 03-12-2014, 03:22 PM
