1. Gevio WhiteWizard's Avatar
    Which android version is more practic , and can i uptade to android kit kat ?
    03-08-2014 02:50 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's hard to say which version is more "practical." KitKat is the most recent version, and has various improvements and new features compared with Jellybean. However, there's always the possibility of a device having problems after any system update, because the modifications that the manufacturer or the wireless carrier make to the OS update can sometimes cause problems.
    If your phone is unrooted (i.e., not modified to superuser status, which is not for beginners), then you can only update the OS if and when the manufacturer of your phone as well as your wireless carrier see fit to release an update. What phone do you have?
    Golfdriver97 likes this.
    03-08-2014 03:01 PM
  3. Gevio WhiteWizard's Avatar
    Galaxy tab 3 , thanks for your reply
    03-08-2014 03:55 PM
  4. B. Diddy's Avatar
    Go to Settings>About Tablet>System Updates, and check for system updates there.
    03-08-2014 04:01 PM
  1. Things I want in Android 4.5 (stock Android.)
    By ViperAlliance in forum Android 4.4 KitKat
    Last Post: 03-10-2014, 10:18 AM
  2. RAM: 2GB vs 1GB in 2014
    By Iron Mew in forum General Help and How To
    Last Post: 03-08-2014, 11:52 AM
  3. Android version: 4.1.2 - SIM network unlock PIN
    By viennaamar in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-08-2014, 09:44 AM
  4. Samsung Note 10.1 2014 VS MS Surface 2 (RT) ?
    By Daaku Singh in forum General News & Discussion
    Last Post: 03-07-2014, 12:53 PM
